M20
Revision as of 09:19, 29 October 2014 by Grrrmachine (talk | contribs)
Models
M20 Oil pump and sump gasket
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on the intake side of the block, on a machined flat area just above the sump seal. Type number will start 20 ,25 or 27.
Crank Bolt
  • M20B20 - 130mm
  • M20B25 - 135mm
  • M20B27 - 130mm
  • M21D25 - 130mm
The 135mm rod weighs 640g.
M20 Pistons
Ø: 84 84 84 84 84 84 84
ÜH: 4.2 4.2 4.43 3.6 0.65
MT: -6.2 -5.1 1.1 -3.5 -2
Stroke: 75 75 75 81 81 81 81
Crank Pulley
Cross sectional view of the different M20 heads.
Moulds of M20 inlet ports.
Timing Belt
Head Bolts
12 10 4 2 6 8 14
<-- Rear Front -->
13 7 5 1 3 9 11
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Main article: Oil
Oil Pressure Switch
Oil Cooler
Main article: Cooling
Water Pump
Main article: M20 Water Pumps
Thermostat
Expansion Tank
Fan
Rubber Hoses
Prefacelift Cars
  • Pump to thermostat hose: 11531287651
  • Thermostat to rad hose: 11531708826 or for Jetronic cars 11531278926
  • Bottom rad hose: 11531278925
  • Header tank to pump hose: 11531289257
  • Thermostat to heater: 11531289377
  • Throttle body hose: 13541705568
  • Block to throttle body hose: 13541719976
  • Block to heater hose: 64211380527
Facelift Cars
  • Thermostat to rad hose: 11531722216
  • Bottom rad hose: 11531718980
  • Thermostat to bottom rad hose: 11531718982
  • Thermostat to heater and expansion tank hose: 11531722743
  • Throttle body hose: 13541719966
  • Block to throttle body hose: 13541719967
Drain Plug
Not Starting
Oil Leaks
Cracked Head
Stroker Engines
Engine Management
Exhaust Manifolds
Useful websites
See Also
Engines M21 M30
