M21
The M21 is an straight-6 Diesel engine of BMW, whose 12-valve, belt-driven SOHC design in three parts, featuring a main Block with a Sump at the bottom and a Head at the top. It is directly related to the M20 engine.
The M21 was the only diesel engine fitted to the E30, with a single capacity of 2.4 litres. However, there are two versions; with and without turbo.
The M21 was first built in 1983, but it wasn't until 1985 that it saw production use in a BMW. For its first few years, it was trial-fitted to an American car, the Lincoln Continental, before being included into the E28 and E30 engine range.
With a design heavily borrowing from the "baby six" M20 petrol engine, the diesel M21 was BMW's first foray into non-petrol fuels, and the relatively low application of the technology showed how little BMW's faith was in the power plant. For this reason, it went through very little development during its ten-year production period, and yielded only two variants with a single capacity; a 2443cc unit, with or without turbo.
FOr the E30, two distinct models were badged, available as a 4-door Saloon or Touring. The M21 powered the 324d from 1985 to 1990, and the 324td from 1987 to 1993, for the lifetime of the E30 Touring. No diesel Cabriolet was offered.
Despite the length of time for which the diesel was offered, very few units were built, relative to the entire production of the E30. The engine was fairly popular in mainland Europe and the USA, but was never officially sold in Great Britain, which is why very few of these cars are seen on the road today.
| M21D24 | 2.0 L (2443 cc/149 in³) | 63 kW (84 hp) @ 4600 | 152 N·m (112 ft·lbf) @ 2500 | 5150 | 1983 |
| 85 kW (114 hp) @ 4800 | 220 N·m (163 ft·lbf) @ 2400 | 5350 | 1987 |
The lowest part of the M21 engine is the Sump, an aluminium dish that provides an oil bath for the crankshaft, as well as feeding the oil pump. Oil is drained through a single bolt,
Almost all M21 sumps are interchangeable between engines, except for that fitted to the 325iX.
Removing the sump on an M21 in situ is one of the most irksome chores on these engines. You can lift the engine out to get better access, but this requires dismantling a large portion of the engine ancillaries. However, you can attempt the following method:
The M21 block is a cast iron design with six cylinders. All M21 blocks have an 80mm bore, just like the M20B20 petrol engine.
The M21 crank shaft has a stroke of 81mm.
The crankshaft is arguably the most famous component of the M21, since it shares the same throw as the M20B25 engine fitted to the 325i. However, since diesel engines are built much more ruggedly, the crankshaft is made of forged steel. For that purpose it is a very desirable part for those fitting a turbo to their own engine.
Both ends of the crank shaft protrude through the block. The front end carries a number of pulleys to control engine timing and to power engine ancillaries, while the rear holds a wheel to bolt to the flywheel. To prevent oil leaking through the block, an oil seal is fitted at either end of the crank inside each end main bearing. These oil seals rarely fail on the M21 engine.
M21 cranks have seven main bearings and six piston rod bearings. The main bearing bolts can be re-used, but the piston rod bolts ('big end' bolts) are stretch bolts and must be replaced.
Crank Bolt
Only one length of rod was fitted to the M21 engine; 130mm
| M21D24 22:1 | M21D24 22:1 | |
| 85-90 | 87-93 | |
| Ø: | 80 | 80 |
| KH: | 42.4 | 46.4 |
| MT: | 3.13 | 2 |
| GL: | 62.4 | 76.3 |
| BO: | 22.0 x 54 | 26.0 x 69 |
| Stroke: | 81 | 81 |
| Conrod Length: | 130 | 130 |
| Volume | 2443 | 2443 |
| Piston Shape: |
Crank Pulley
A single head design was used for both turbo and non-turbo versions of the M21. This aluminium core featured a design very similar to the M20 unit.
It is not uncommon for these heads to develop cracks between the valve ports, although this does not render the head useless. Modern welding techniques mean that the head can be repaired if necessary, and while the cost is currently very expensive, it is still cheaper than trying to source a new head. The problem of cracking is so prevalent that it is now very hard to find a used head that does not have at least one crack.
Despite the two types of engine, the rocker cover is interchangeable between the versions. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, one port for the breather hose, and a final port on its top for the vacuum pump.
Cam
An overhead camshaft drives the intake and exhaust valves through rocker arms. This camshaft is belt-driven on the M21 engine. The cam is held in place using up to 7 bearings. The end of the cam protrudes from the engine to drive the distributor.
The cam has the following specifications:
Lift: 6.580mm Duration: 249° (intake) 260° (exhaust) LCA: 113.50° (intake) / 112.00° (exhaust)
The cam is also responsible for driving the vacuum pump, mounted inside the head.
Vacuum Pump
Like many diesel engines, a vacuum pump is fitted to create vacuum force to drive the brakes. This is because, unlike petrol engines, there is very little negative pressure in the engine head, since diesels do not "suck" air in the way that petrol engines do.
The M21 vacuum pump sits to the rear of the head (close to the bulkhead), and its shape is distinctive underneath the rocker cover. A single pipe exits the pump through the rocker cover, primarily to power the brake servo.
Two types of valves are fitted into an M21 head; Intake valves and Exhaust valves. Because the M21 is an interference engine, this means that the valves protrude into the cylinder when opened; for this reason, any problem with the timing belt will automatically mean damage to at least three valves. The valves are adjusted at the rocker arms, and should be set to 0.3mm when cold.
The diesel valves are a specific size, and are becoming increasingly hard to source. For reference, intake valves are 35mm intake and the exhaust are 31mm.
Rocker Arms
Breather Hose
To balance the pressure inside the head, a rubber hose runs from the top of the rocker cover to the crank case. On turbo models, a second hose also runs to the air filter box.
Glow Plugs
Since diesels create combustion using heat and pressure rather than Ignition, there is no need for spark plugs. Instead, the latent heat of the engine in operation is enough to detonate the diesel fuel once it is compressed.
However, when starting from cold there is not enough heat in the system to initiate those first few explosions, so electric heaters known as glow plugs are fitted. These fixed-point heaters rapidly heat up the fuel in the cylinder so that it will detonate when compressed. Six glow plugs are fitted to the M21; one for each cylinder.
The glow plugs are circuit-controlled, connected to the thermostat and coolant temperature sensor. When the coolant reaches a level of 60°C (140°F) the glow plugs will shut off.
Diesel models will have extra lights fitted to their instruments to inform the driver of the state of the glow plugs. One is green, the other orange. The orange light stays on when the glow plugs are heating, and after they click off the green light should turn on to tell you that the engine is ready to be started. If the green light does not turn on you probably have a dead glow plug. Replacing the glow plugs will usually make the green light work again.
Ancillaries
Turbo
Main article: Forced Induction
Only one E30 model was fitted with a turbocharger; the 324td. However, identical components were used on the E28 524td.
The turbo is a standard forced-induction unit, whereby exhaust gases are used to drive a turbine, whose subsequent spinning forces more air through the Intake side of the engine. This increase in air flow allows more fuel to be added, thus providing more power.
The turbo itself was a variant of the standard T3 design including an internal wastegate, and was made by AiResearch (Garrett). It was had a connection to the main block for lubrication, and was connected to an intercooler to reduce the temperature of air on the intake side.
One of the most common reasons for non-functioning turbos relates to the EGR valve.
EGR
The Exhaust Gas Recirculation valve, or EGR, is a polution control device. Its purpose is to scavenge a portion of the exhaust gases and return them to the cylinders for re-use.
The EGR is sits right underneath the turbo, on the manifold. It has a pipe that runs from there to the intake pipe. Also from the EGR is a vacuum tube that runs to something called the aneroid diaphragm, which is right behind the driver's side strut tower. From there the pipework goes to a solenoid on the firewall, and from there more pipes run elsewhere, all of which are unnecessary once you remove the EGR.
The EGR is an extremely problematic system, since it blows all your exhaust right back into the intake, thus mixing soot with a little bit of oil to create a sludgey concoction that lines the intake ports and the top of the valves, ultimately reducing power. It is a very common modification to remove the EGR, blank off its port and to re-route the associated plumbing so seal the leaks.
The M21 flywheel, like all flywheels, keeps the engine spinning long after you take your foot off the throttle. It is also the flat surface to which the clutch mates, ultimately transferring power from the engine to the Drivetrain. The edge of the flywheel is toothed. Known as the ring gear, it is what allows the starter motor to bite onto the engine to start it. The flywheel bots to a pulley at the end of the crank.
Two weights of flywheel were fitted to M21 engines. The standard single mass flywheel is 12.1kg, fitted to to the 324d and early 324td models. Later turbo models were fitted with a slightly lighter dual-mass unit of 11.9kg. This latter flywheel was also fitted to diesel versions of the E34 fitted with the later M51 diesel engine. It is designed to be used in conjunction with a pulse generator, which sends a signal to the control unit for the glow plugs.
The starter motor is a standard 2.2kW motor with a bendix engagement wheel. It is an all-in-one unit containing motor, solenoid and relay. When activated, the starter gear extends to meet the flywheel and then spins, driving the engine.
It is very rare for M21 starter motors to fail. If you are having problems starting your car, it is recommended to look at the common problems of E30s before removing the starter motor.
Engine Mounts
The engine mounts are standard on all M21-equipped E30s; however, if you are taking an engine from an E28, you will need E30 engine mounts.
Fuel
Main article: Diesel
Unlike all the petrol engines fitted to the E30, the M21 has an exclusive system that cannot be covered in the normal fuel section of this Wiki. However, a number of components are shared; the system still revolves around pressurised fuel, collected from a tank and delivered to injectors by way of a pump. It is only the technicalities that make the system so different.
Fuel Pump
The diesel pump was available in two flavours. The earlier system fitted to the 324d was cable-driven and directly controlled by the accelerator pedal. This was replaced by a later fly-by-wire system for the 324td that read data from a throttle pedal sensor. Both of these systems employed a belt-driven pump with a DDE ECU to control injector cycling, with the later system employing a second DDE to read the throttle data. The pumps on these two systems are clearly different, and not interchangeable.
Injectors
The injectors work like all injectors; fuel is pressurised by the fuel system and delivered to the injector. When required, the injector pulses open, atomising the fuel into the cylinder. The specifics for diesel engines is that each injector connects directly to the pump, unlike petrol engines (which employ a fuel rail). For the two types of pumps, there are two types of injector.
Number 4 injector also contains a transmitter sensor, known as the needle lift sensor.
There are two main parts of the injectors that wear. The spring loses tension over its life. This tension loss causes the nozzle to open at a lower pressure than is optimal which results in bad fuel atomization and an increase in fuel delivery to the cylinder. The second piece that wears are the nozzles. The mating surfaces of the nozzles get pounded continuously which results in a less than optimum sealing surface and an enlarging of the orifice. This enlargement results in a richer than optimal condition which increases fuelling and reduces economy. Both of these wear parts wear at different rates between injectors and can cause one injector to be very rich compared to the others. This rich cylinder(s) causes the black smoke that may be present on starting, during idling and under load.
Oil
Main article: Oil
Oil Pressure Switch
Oil Cooler
Both the 324d and 324td have an external oil cooler fitted and mounted under the normal engine radiator. It receives cool air through vents in the front valance. However, with modern semi-synthetic oils, the oil cooler is rather redundant, despite the increased temperature that diesel engines operate at.
Main article: Cooling
The M21 block is filled with channels for a liquid coolant. These channels are known as the water jacket, and are designed to allow coolant to flow from the the bottom to the top of the engine and out. Pressurised by a water pump, the coolant flows out to the radiator where it is cooled by air flow through the grille. In the case of high engine temperature, extra cooling is provided by a viscous fan mounted behind the radiator.
Water Pump
There are two types of water pump fitted to M21 engines, depending on the age of the engine, and are distinguished by the number of pipe outlets fitted.
Thermostat
The M21 radiator is an aluminium core with plastic side tanks, and is bolted to the front valance of the vehicle. A plastic 'shroud' guides air flow around the rear of the radiator, as well as channelling air blown in by the fan.
Expansion Tank
Fan
The cooling fan fitted to all M21 engines is driven by the water pump, and uses a viscous clutch to regulate its speed. This is a known weak spot of the engine, with a failing clutch causing the engine temperature to rise dramatically when the car is left to idle.
Rubber Hoses
All the elements of the cooling system are linked with a series of rubber hoses. The seven hoses that make up the cooling system are as follows:
- Pump to thermostat hose: 11531275398
- Thermostat to rad hose: 11532241078
- Thermostat to heater and expansion tank hose: 11532241836
- Block to radiator hose: 11532241898
- Block to heater hose: 64211386425
Drain Plug
To properly drain the coolant from the M21, it is not advisable to simply remove bottom hose. Because of the complex design of the M21 water jacket, there will still be pockets of coolant left in the block and, if the system is being flushed, dirt and grime will still be trapped inside.
Because of this, a bolt is fitted to all M21 blocks to properly drain the water jacket. This bolt is located below the exhaust manifold to the rear of the engine, and is best undone with a 19mm ring spanner.
