E30
Models
Base models
Name | Volume | Engine code | Years | No. Produced |
316 | 1766cc | M10B18 | 1982–1987 | |
316i | 1596cc | M40B16 | 1987–1994 | |
318i | 1766cc 1796cc |
M10B18 M40B18 |
1982–1990 1987–1995 |
89,637 |
320i | 1990cc | M20B20 | 1982–1991 | |
323i | 2316cc | M20B23 | 1982–19850 | 60,706 |
325i | 2494cc | M20B25 | 1982–1990 | 196,996 |
324d | 2443cc | M21D24 | 1985–1993 | 75,696 |
324td | 2443cc | M21D24 | 1985–1993 | 21,514 |
Sports
318iS | 1766cc | M42B18 | 1989–1991 | 41,234 |
325i Sport | 2494cc | M20B25 | 1986–1991 | |
325i Motorsport | 2494cc | M20B25 | 1986–1991 | 590 |
M3 | 2302cc | S14 | 1986–1991 | 17,184 |
M3 Evolution | 2302cc | S14 | 1987–1987 | |
M3 Evolution II | 2302cc | S14 | 1988–1988 | |
M3 Sport Evolution | 2467cc | S14 | 1990–1990 |
Overseas Models
Europe
320iS | 1990cc | S14B20 | 1987–1990 | 3,748 |
325iX | 2494cc | M20B25 | 1982–1990 | 29,589 |
South Africa
325iS | 2693cc | M20B27 | 1990–1991 | |
333i | 3210cc | M30 | 1985–1987 | 204 |
North America
325e | 2693cc | M20B25 | 1982–1990 | 189,287 |
Variants
Alpina
Hartge
Brochures
A selection of brochures from all around the world, ranging from Genuine BMW, through the tuning companies to after market accessories. Brochures
Dimensions and Weights
Dimensions | Saloon | Touring | Cabriolet |
Length | 4325mm | 4450mm | |
Width | 1645mm | ||
Height (unloaded) | 1380mm | 1370mm | |
Wheelbase | 2570mm | ||
Front overhang | 761mm | 845mm | |
Rear overhang | 994mm | 1075mm | |
Front track | 1407mm | ||
Rear track | 1415mm | ||
Min. turning circle (wheels) | 9.8m | ||
Min. turning circle (overall) | 10.5m | ||
Boot capacity | 404 litres | 312 litres |
Weights | 316 | 316i | 318i
with catalyst |
320i | 325e | 325i | 325iX | 324d | 325i | 325i |
Unladen weight | 1000kg | 1010kg | 1020kg | 1080kg | 1120kg | 1125kg | 1215kg | 1155kg | 1275kg | 1355kg |
Max. weight limit | 1460kg | 1470kg | 1480kg | 1540kg | 1580kg | 1585kg | 1675kg | 1615kg | 1715kg | 1735kg |
Front axle load limit | 750kg | 7760kg | 760kg | 810kg | 800kg | 800kg | 855kg | 820kg | 830kg | 860kg |
Rear axle load limit | 825kg | 825kg | 825kg | 825kg | 890kg | 890kg | 900kg | 890kg | 960kg | 945kg |
Trailer load limits | ||||||||||
Unbraked | 500kg | |||||||||
Braked | 1200kg | |||||||||
Max. roof load | 75kg | 50kg |
- for 4-door saloons, add 20kg
- for automatic transmissions, add 20kg
Technical
- Main article: Technical
Engines
- Main article: Engines
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
While moving in the E30 is an utterly delight, the need to stop moving is sometimes necessary. For that reason, the E30 was fitted with front discs on all models. The smaller-powered 316, 316i and 318i saloons were fitted with rear drum brakes, while all six-cylinder models and Tourings had rear discs as standard.
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
Interior
- Main article: Interior
The interior of the vehicle is where the E30 owner experiences the car. From its upholstery to its instruments and everything in between, learn more about the Interior here.
Electrical
- Main article: Electrical
Customisation
Power
M-Technic
- Main article: M-Tech
