318iS
One of the last models of the E30 range to be added was the 318iS - a 2 door saloon. The 318iS was fitted with the M42 engine, the most up-date-engine fitted to any E30. It came with Sports Suspension (including rear Anti Roll Bars - ARBS), sports seats front vented discs; rear solid discs, power steering, electric windows, electric mirrors, de-chromed trim, M-tech steering wheel, leather gear knob and gaiter, front and rear spoilers and BMW sport seats. The 318iS did NOT come with a limited slip differential as standard but was a small case differential with a 4.10 ratio. The base model cost aproximately £14,750 when it was new. It started out life to beat the sports models that Volkswagon and other leading car manufacturers were producing (such as the golf GTI. Bmw set out to produce a sports BMW which would match/ beat the performance of the likes of the GTI with a 1800cc BMW. At this moment in time, the only E30 BMW capable of out-performing the GTI was the 325i. The M42 16V DOHC engine was developed which produced 136BHP and was one of the most technologically advanced engine for its time and is also one of the most fuel economic E30's achieving around the 33MPG with mixed driving . There were rumours that the 318iS actually out-performed BMWs own 325i, so they restricted the power so the sales of the more expensive 325i wasn't effected. But still with 126BHP/tonne, it still gives the 323i a good run for its money. In total, 41,234 318iS's were made which means that out of the full 2.2 million E30's, 1.86% of them were 318iS's. In 2001 the DVLA only had 1687 318iS's registered in the UK, the number has since thought to of fallen to around 900 which is making the 318iS becoming more valuable and sought after.
Technical
Engine
Main article: M42
Fuel System
Test pressure: 3 Bar/43psi
Ejection angle: 30 deg
Ignition
Motronic : Bosch DME 0-261-200-175 Software version 1.7 (US details)
Spark plugs : 16mm 3 electrode NGK BKR6EK or Bosch F7LDCR. The Champion RC8DMC can be used too. Note a 4 electrode platinum plug has
Plug gap : As specified above, they are unadjustable (pregapped) otherwise 0.027"
Idle Speed : 850rpm
Techincal info
Front settings : Castor 8½º ± ½, Camber -2/3rdsº ± ½, Toe-in 0.028" ± 0.024, Steering axis inclination 13 5/6thsº ± ½
Rear settings : Camber -2º ± ½, Toe-in 0.080" ± 0.031
Tyres : 195/65/V14 205/55/V15
Wheels : 14"x6", 14"x6.5", 15"x7", 4x100 cts mm bolt holes, centre hubs are 57mm, wheel bore 57.1mm
Wheel offsets :
6" rim width: 35mm offset
6½" rim width: 30mm offset
7" rim width: 25mm offset
Braking
Front : ATE or Hoeflinger Ventilated disc, 10.24" diameter Rear : ATE or Hoeflinger Soild disc, 10.16" diameter Handbrake: Drum, integral with rear disc, manually adjusted internally at rear of lever. Shoes usually last the lifetime of the car. Calipers: ATE or Girling Master cylinder: ATE Recommended Fluid: DOT 4 - BMW recommend changing the fluid every 24 months. I would recommend changing it before and after a track session also.
Rear pads: I use Pagid 0307NA
Minimum pad thickness = 2mm
Lubrication Engine : Fully or semi-synthetic, 15W-50 depending on environmental temperatures (although I would recommend a 5W40, 5W50 or 10W50 fully sythetic) - 4.5 litres, 5.26 qrts Engine oil filter : Hengst E88H D24, in bowl type Gearbox : 1.2 litres, 2.5 pts BMW Mobile traditions CD-Rom designates DEXRON II automatic transmission fluid Differential : Castrol SAF-X0 75W-90 or Castrol Synthrax or Hypoid 90 (for open diffs). Castrol SAF-XLS for Limited Slip Diffs. Also see Castrol's website.
Main article: Common M42 Problems page
As favoured as the M42 engine is, it's not perfect, and has its own quirks that show up regularly. Aside from the lumpy idle and fuel smell that can plague all E30s, the 318iS is especially prone to ticking and tapping noises, profile gasket failure and problems with the timing chain tensioner.
Common upgrades
Performance
Performance stats chart
  • Figures for E30 taken with a crew of two and a full fuel tank.
Max BHP : 136bhp @ 6000rpm Max Torque : 127 ft-lbs @ 4600rpm BHP/Litre : 75.6 Official MPG (Urban) : 26.9 Official MPG @ 56mph : 47.9 Official MPG @ 75mph : 37.2 30 to 50 mph in 4th/5th : 8.5/12.8 secs 40 to 60 mph in 4th/5th : 9.2/13.2 secs 50 to 70 mph in 4th/5th : 9.6/13.4 secs 60 to 80 mph in 4th/5th : 9.0/14.6 secs 70 to 90 mph in 4th/5th : 9.7/17.3 secs
Useful websites
BMW ETK
BP's E30 318iS website
The M42 engine club
318IS magazine spread
General Info
Wheel base = 101.2"
