M42
E36 Differences
If you have bought an E36 lump, you will need to swap the following components to E30-specific parts to fit your car:
Sump Gasket
The block itself is a pearlitic cast iron unit, with a central bore of 84mm and a bore spacing of 91mm. The cylinders have a maximum ovality of: 0.01mm/0.0004" with an identical maximum taper. Compression pressure is 10-11bar (143-156psi), with a compression ratio of 10:1.
- M44 - 83.5mm stroke
- M47 - 88mm stroke
The crankshaft has an endplay tolerance of 0.0031-0.0064". If your engine has more than this, consider replacing the pilot bearing.
One size of piston was used for M42 engines, featuring a small dish to provide 20% of the combustion area, as well as notches for valve interference.
| Engine | M42B18 10:1 |
| Year | 1989-95 |
| Ø: | 84 |
| KH: | 31.650 |
| ÜH: | 0 |
| VT: | 1.650 |
| MT: | 4.500 |
| GL: | 51.150 |
| BO: | 22.0 x 54 |
| Stroke: | 81 |
| Conrod Length: | 140 |
| Volume | 1796 |
| Deck | 212.15 |
| Piston Shape: |
Cams
Being a 16V engine, the M42 head features two camshafts; an Intake and an Exhaust. These cams operate directly on the valves.
| Inlet | Exhaust | |
| Duration | 252 | 252 |
| Lift | 10.2 | 10.2 |
| Lobe height | 1.8755-1.8803" | |
Valves came with stems in two sizes; 7mm for earlier engines, or 6mm after September 1992. All valves are double-sprung.
| Inlet | Exhaust | |
| Head diameter | 33mm | 30.5mm |
| Seat diameter | 31.6mm | 29.1mm |
| Seat width | 1.4-1.9mm | 1.4-1.9mm |
Timing Chain
Other causes of failure are due to known weak points in the chain gear. The weakest is the steel chain guide, which can fracture and break. An indication of a worn guide is a noticeable increase in chain rattle; the engine will sound significantly louder. Guides can be replaced with an upgraded dealer part made of nylon/plastic. You will need one new 45mm long bolt in conjunction with the new guide.
Breather Hose
Intake Manifold
The inlet manifold is a two pieces design, comprising of an upper and lower manifold. The design is aimed at improving the low down torque of the engine.
If fitting an M42 to your car from an E36, it's not essential to replace the intake manifold; however, there are differences between the E30 and E36 variants. The E30 version is designed for better top-end performance, while the E36 unit yields better torque at lower revs.
Throttle Body
There is a lot of debate regarding M42 flywheels. Some engines were fitted with a dual-mass flywheel while others retained a solid single-mass wheel, which is considered to be more desirable. Dual-mass wheels are more commonly found in the US, while the UK market seems to have retained the single-mass wheel.
Torques
| Nm | ft-lbs | |
| Flywheel | 82-94 | |
Profile Gasket
At this stage, most E30 M42's should have had their profile gasket replaced through by a dealer or by previous failure. It would be worthwhile checking with previous owners on when and who replaced the gasket, although you may have to go back a number of years into the car's history. If you cannot determine if it has been replaced, assume that it has, considering the mileage of cars that are now at least twenty years old.
However, keep in eye out for water in oil symptoms (a grey-brown sludge build up easily evident on the oil filler cap or dipstick), unusual oil pressures, water loss (leaks or otherwise) or water temperatures.
Timing Chain Tensioner
Tapping/ticking noise
When most people hear a ticking engine they instantly believe that the tappets are worn. This is not always the case, sometimes it can be a crack in the exhaust manifold. Normally the ticking will go away once the car has been driven for a while, so people believe the the oil has reached operating temperature and cured the tapping problem. However, it could be a small hole in the exhaust manifold that is sealed when the manifold gets hot (ie expanding metal covering the hole up!). This is most common on cylinder one.
Fuel smell
Some times you can smell petrol fumes on startup, which can smell a lot worse if you turn on your fans. This can be a small fuel pipe just behind the inlet manifold which can perish or sometimes just needs the jubilee clip tightening. Petrol cannot always been seen (unless the engine is cold) as the petrol instantly evaporates from the heat of the engine. But you should see the leak leaking onto the fuel rail trim and down the fuel inlet and return pipes for the engine.
Lumpy idle
The M42 engine is prone to the air breather pipes perishing. This results in unwillingness to start on cold mornings and a lumpy uneven idle. If you open the bonnet with the engine running you may be able to hear a hissing sound. Then all you need to play is hunt the sound considering there are a lot of breather pipes to the engine. If there is no hissing sound it could be the valve in the idle control valve (ICV) sticking. Simply disconnect the ICV by undoing the jubilee clips (its found between the engine and bulkhead on the passenger side and is a "T" shape) and spray some carburettor cleaner into the valve. This should stop the valve from sticking, or you could replace the ICV completely.
Loose Sump Bolts
Coil On Plug
Throttle Body Heater Delete
M20 Flywheel
Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road friendly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembly.
It is common that the M20 flywheel will rub on the M42 sump. Some people grind down the parts of the sump where it touches, but it is not really the proper way. The best thing to do is get the back of the flywheel machined down,which would be lightening it too so is worth while doing. The flywheel would then have to be balanced.
Chips
Stroker Engines
