Engines
List of Engines
Name | Engine code | Volume | Engine | Valvetrain | Fuel | Output | Torque | Years |
316 | M10B18 | 1766cc | 4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | 1982–1987 |
316i | M40B16 | 1596cc | 4cyl | SOHC 8V | Petrol | 102hp (75kW) @4500 rpm | 105ft/lb (140Nm) @4250 rpm | 1987–1994 |
318i | M10B18 M40B18 |
1766cc 1796cc |
1982–1990 1987–1995 |
318iS | M42B18 | 1766cc | 4cyl | DOHC 16V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | 1989–1991 |
320i | M20B20 | 1990cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @5800 rpm 127hp (95kW) @6000 rpm |
1982–1985 1985–1991 |
320iS | S14 | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @6750 rpm | 155ft/lb (210Nm) @4750 rpm | 1982–1990 |
323i | M20B23 | 2316cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4000 rpm | 1982–1985 |
325e | M20B27 | 2693cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4250 rpm | 169ft/lb (230Nm) @3200 rpm | 1982–1990 |
325i | M20B25 | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | 1982–1990 |
325iX | M20B25 | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | 1982–1990 |
M3 | S14 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm 212hp (158kW) @6750 rpm |
1986–1988 1989–1991 |
M3 Evolution | S14 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | 1987–1987 |
M3 Evolution II | S14 | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @6750 rpm | 181ft/lb (0Nm) @4750 rpm | 1988–1988 |
M3 Sport Evolution | S14 | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @6750 rpm | 177ft/lb (0Nm) @4750 rpm | 1990–1990 |
324d | M21D24 | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | 1985–1993 |
324td | M21D24 | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | 1985–1993 |
Special engines
Ancillaries
Fuel
Main article: Fuel
Air
Main article: Intake
Spark
Main article: Ignition
Starter
Main article: Starter
Your petrol motor needs an electric motor to get it started. This motor spins the engine up to the speed needed for normal combustion to work - once those are happening, the starter will disengage.
The starter for all E30 engines sits on the intake side of the engine, and is bolted to the gearbox. It has direct heavy-duty wiring to the alternator and battery, and grounds through the engine block to the car chassis. It is triggered by wiring directly from the ignition switch.
Starters are specific to each engine, because the gear teeth of the starter cog has to match the teeth on the engine flywheel. What's more, there is a difference between early and late M20 starters due to a change in flywheel in 1987.
Exhaust
Main article: Exhaust
Engine Management
Main article: Cooling
Oil
Main article: Oil
Engine Swaps
Main article: Engine Swaps
Aside from swapping between engines within the E30 line-up, the following BMW engines have also proved to fit under the bonnet:
Troubleshooting
