Engines Troubleshoot
Troubleshoot
The troubleshooting table is a clickable diagram to help you solve your engine woes.
START charge battery Test Inhibitor switch
(Auto only)
Test Starter connections
inc. earth strap
Does the engine crank? Does the battery have 12V? Diagnostic Plug Start Starter Motor
test bulb on coil Ignition Switch green wire Check for 12V
at C101 pin 7
Does it glow? Immobiliser or OBC? bridge wire to coil Check for 12V
on ECU pin 27
Does the ICV buzz
with IGN on?
Check for 12V on DME Relay
pins 87 with IGN on
Listen for the fuel pump running
and check for spark at the spark plugs
↓ ↓ →Both→ Test Blue Temp Sensor Small red wire from battery Check for 12V on DME Relay
pins 86 and 30 with IGN on
Sparks but no Fuel ↓ ↓ Check for air leaks DME Relay Is Pin 85 grounded
with IGN on?
Check for power at Injectors ↓ →Neither→ Check Flywheel pin (Jetronic) Test CPS Replace ECU
Fuel pumps, but no spark Check for spark from coil Check Ignition Module
(Jetronic)
Cam belt Check Distributor and rotor Test Coil
Bridge the Fuel Pump Relay Connect bulb across
Fuel Pump pins
fuel pump Coil King lead
Fuel Pump Relay Fuel pump wire
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
From there, check for breaks inside the car, especially behind the glove box. At this point there is a two-pin socket with one green wire to each pin. If there is an OBC fitted, there will be a plug with one green wire and one green/red wire plugged into it. If there is no OBC and no immobiliser fitted, the socket should have a plug pushed into it with a short loop of green wire between its pins. If you have recently interfered with or removed the OBC, then these wires will be unplugged and the engine won't start. To solve them, either ensure the plug is connected firmly to the OBC (if fitted), or for a guaranteed repair, cut the plug off and join the two wires.
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
The sender is screwed into the pump with four bolts, and has its own electrical connection. IGNORE this connector; you want the plug to the pump itself. Simply pull it off the pump, and connect your 12V 5W bulb across the terminals inside the plug. When you crank the engine, the bulb should glow.
If it does not glow, and you have followed all the preceding steps, then the wire between the fuel pump relay and the pump is damaged.
To examine the wire, look for the green/purple wire which emerges from the duct from the bottom of the fusebox, behind the steering column on LH drive, goes across to behind the top of the speaker panel, down behind the front of the panel, and then the back of the LH sill to the fuel pump.
12V At ECU
Ignition Switch
First thing to do is to check you have a good +12v signal coming out of the ignition switch when you try to start the engine. Connect your 12V 5W test light between ground and the yellow/black wire at the socket where the ignition switch plugs into the main loom at the steering column. If you don't get a good supply from there (test light does not light up brightly), your switch is most likely faulty.
If you do get a good bright light, get in behind the glove box and find the plug where you can split the black/yellow wire (this is where the auto loom plugs in- its purpose is to isolate the starter if not in park or neutral). Check that the connection is good and then connect the test light on the motor side of the plug and check that it lights brightly when attempting to start.
Hopefully now you will have found your fault as the only bit left is the wire between C101 and the starter solenoid, and this is unlikely to be faulty given the fact that the car swings over readily from the diagnostic socket. But check it anyway, clean the terminal on the starter and hopefully it will be good to go!
Check for Spark
