ECU Pinouts
Jetronic
Jetronic's primitive management system only controlled fuelling, so the ECU is little more than an injection control unit. The control model uses a 25-pin plug, with Pin 1 at the cable end. Note that the ECU connector is accompanied by the C104, a small 3-pin plug that provides data for the Instruments.
Pin | Colour | Function | Pin | Colour | Function | Image |
1 | GN | Engine Speed input (RPM) | 14 | ![]() | ||
2 | BR/BU | Closed Throttle input | 15 | |||
3 | BR/BK | WOT input | 16 | |||
4 | BK/YL | Cranking signal | 17 | |||
5 | BR | Ground | 18 | BU/BR | Cancels deceleration fuel shutoff when A/C clutch is on | |
6 | GN/RD | Engine Load Output to Vacuum Control | 19 | |||
7 | GY/YL | AFM input | 20 | GN | O2 Sensor input | |
8 | GN/VI | AFM reference output | 21 | |||
9 | RD/WT | Power input | 22 | WT/GN | Fuel rate to Diagnostic plug | |
10 | BR/RD | Coolant Temp input | 23 | |||
11 | WT | Barometric Pressure input | 24 | |||
12 | BR/YL | Injectors and Econometer | 25 | |||
13 | BR | Ground | ||||
C104 | ||||||
1 | BL/BU | Tachometer | 2 | |||
3 | WT | Econometer |
Motronic 1.0
Pin | Function | Pin | Function | Image |
1 | Ignition coil output | 19 | Ground | ![]() |
2 | Idle switch | 20 | Main relay | |
3 | WOT switch | 21 | Tachometer | |
4 | Cranking signal | 22 | AFM Temp sensor | |
5 | Ground/Crank PosS Gnd | 23 | Inlet Air Temp/Crank SpS Gnd | |
6 | AFM ground | 24 | O2 sensor signal * | |
7 | AFM signal | 25 | Crank position sensor 1 | |
8 | Crank speed sensor 1 | 26 | Crank position sensor 2 | |
9 | AFM supply | 27 | Crank speed sensor 2 | |
10 | Auto only special | 28 | Water Pressure switch | |
11 | Fuel consumption gauge | 29 | A/C switch (if installed) | |
12 | 30 | +Inlet Air Temp | ||
13 | Water Temp | 31 | ||
14 | Injector output cyl 3&4 | 32 | ||
15 | Injector output cyl 1&2 | 33 | ICV pulse | |
16 | Ground | 34 | ICV pulse | |
17 | Ground | 35 | Injector ground | |
18 |
Motronic 1.1
Motronic 1.1 uses a much chunkier plug, fitting 55 pins into three rows. Unlike Jetronic and Motronic 1.0, pin 1 is now at the end furthest from the cable.
Pin | Function | Pin | Function | Pin | Function | Image |
1 | Timing Control - to coil and O2 sensor | 20 | 38 | ![]() | ||
2 | Ground | 21 | 39 | Programming voltage - Diagnostic Plug | ||
3 | Fuel pump relay control | 22 | Idle speed control | 40 | A/C on input | |
4 | Idle speed control | 23 | O2 sensor heater | 41 | ||
5 | Evaporative purge valve | 24 | Ground | 42 | Park/ neutral input (auto only) | |
6 | Engine Speed output- to instrument cluster | 25 | 43 | |||
7 | AFM input - pin 2 | 26 | AFM common- ground pin 4 | 44 | AFM air inlet temp- pin 1 | |
8 | Cylinder ID sensor input | 27 | Start input- to ignition switch and coil | 45 | Coolant Temp input | |
9 | 28 | O2 input | 46 | |||
10 | O2 sensor ground | 29 | 47 | Engine speed input | ||
11 | 30 | 48 | Engine speed input | |||
12 | AFM reference output- pin 3 | 31 | Cylinder ID sensor input | 49 | ||
13 | RXO - diagnostic plug | 32 | Econometer | 50 | ||
14 | Ground | 33 | 51 | |||
15 | Check engine light - to cluster | 34 | 52 | Closed throttle input - pin 1 | ||
16 | Injectors 1,3,5 | 35 | 53 | WOT input - pin 3
Note: TPS pin 2 is ground | ||
17 | Injectors 2,4,6 | 36 | Main relay | 54 | ||
18 | Power input main relay | 37 | Power input - to main relay | 55 | TXD - diagnostic plug | |
19 | Ground |
Motronic 1.3
Motronic 1.3 uses the same engine loom as Motronic 1.1, and therefore the 55-pin plug remains the same. However, the small differences that crept into production during the lifetime of Motronic 1.3 mean that a few extra wires are in place, to control features such as ABS.
Pin | Colour | Function | Pin | Colour | Function | Pin | Colour | Function | Image |
1 | BK | Timing Control - to coil and O2 sensor | 20 | 38 | ABS and OBC cutoff for Injectors | ![]() | |||
2 | BR | Ground | 21 | 39 | GN/BU | Programming voltage - Diagnostic Plug | |||
3 | BR/GN | Fuel pump relay control | 22 | WT/GN | Idle speed Close control | 40 | BK/GY | A/C low pressure cutoff | |
4 | WT/YL | Idle speed control | 23 | BR/GR | O2 sensor heater | 41 | VI/GY | A/C On input | |
5 | BR | Evaporative purge valve | 24 | BR | Ground | 42 | RD/BU | Park/ neutral input (auto only) | |
6 | BK | Tachometer | 25 | 43 | |||||
7 | GY/YL | AFM input - pin 2 | 26 | GY/BU | AFM common- ground pin 4 | 44 | GY/VI | AFM air inlet temp- pin 1 | |
8 | BL | Cylinder ID sensor input | 27 | GN | Start input- to ignition switch and coil from OBC | 45 | BR/RD | Coolant Temp input | |
9 | 28 | BK | O2 input | 46 | |||||
10 | YL | O2 sensor ground | 29 | BK/WT | Vehicle Speed input from instrument cluster | 47 | BL | Engine speed input | |
11 | 30 | 48 | YL | Engine speed input | |||||
12 | GY/WT | AFM reference output- pin 3 | 31 | YL | Cylinder ID sensor input | 49 | |||
13 | WT/YL | RXO - diagnostic plug | 32 | WT/BL | Econometer | 50 | ABS Deceleration Fuel Cut-Off Overide | ||
14 | BR | Injector Ground | 33 | 51 | Auto Kick-Down Switch input | ||||
15 | GY | Check engine light - to cluster | 34 | 52 | BR/BL | Closed throttle input - pin 1 | |||
16 | BR/WT | Injectors 1,3,5 | 35 | 53 | BR/BL | WOT input - pin 3
Note: TPS pin 2 is ground | |||
17 | BR/YL | Injectors 2,4,6 | 36 | BR | Main relay output | 54 | Automatic Transmission Torque Converter Lock-up Switch | ||
18 | RD | Constant 12V from Battery | 37 | RD/BU | Switched power from main relay | 55 | WT/VI | TXD - diagnostic plug | |
19 | BR/OR | Main Ground |
Motronic 1.7
The Motronic 1.7 system was exclusive to the 318iS before being fitted to the E36. For all you 16Vers, this table was taken from the E36 handbook; hopefully it will prove to be applicable to the E30 as well.
1 | Fuel pump relay output | 29 | ICV output | 56 | Ignition switch input | ![]() |
2 | 30 | 57-58 | ||||
3 | Injectors 2 and 4 | 31 | 59 | TPS and VAF 5V reference | ||
4 | 32 | Injectors 1 and 3 | 60 | Data link connector input | ||
5 | 33 | 61-63 | ||||
6 | Injector ground | 34 | Ground | 64 | Transmission control input (EGS) | |
7 | 35 | 65 | Automatic transmission range switch | |||
8 | Check engine light | 36 | Evaporative purge valve | 66 | ||
9 | 37 | O2 Sensor heater | 67 | Crank Position Sensor input | ||
10 | 38 | 68 | Crank Position Sensor output | |||
11 | Transmission control input (EGS) - DKV sensor | 39 | 69 | |||
12 | TPS input | 40 | 70 | O2 Sensor input | ||
13 | 41 | Volume Air Flow sensor input | 71 | O2 Sensor ground | ||
14 | Volume Air Flow sensor input | 42 | Cylinders 3-4 knock sensor input | 72 | ||
15 | Cylinders 1-2 knock sensor input | 43 | Ground for temp, knock and throttle sensors | 73 | Vehicle Speed output | |
16 | Cylinder ID sensor input | 44 | Cylinder ID sensor input | 74 | Crankshaft Speed signal TD | |
17 | Fuel consumption for Instruments | 45 | 75 | |||
18 | Intake air resonance takeover valve | 46 | 76 | Volume Air Flow sensor input | ||
19 | 47 | 77 | Volume Air Flow sensor input | |||
20 | 48 | A/C compressor cutout | 78 | Coolant Temp input | ||
21 | 49 | 79-80 | ||||
22 | 50 | 81 | OBC code protection | |||
23 | 51 | Cylinder 4 Ignition Coil | 82-84 | |||
24 | Cylinder 3 Ignition Coil | 52 | Cylinder 2 Ignition Coil | 85 | A/C pressure switch input | |
25 | Cylinder 1 Ignition Coil | 53 | 86 | A/C switch | ||
26 | Battery Voltage input | 54 | Engine control relay output pin 87a | 87 | Data Link Connector RxD | |
27 | Engine control relay output pin 85 | 55 | Ignition Ground | 88 | Data Link Connector TxD | |
28 | Ground |
