Basic M40 Servicing
Just got your first 4 pot E30?!
Scared of the Spanner?!
This guide was made for you!
Basic Servicing
To make your M40 purr like a kitty at idle, roar like a lion through the rev range, and scream like Steve Tyler at the limiter you'll need to give it the following treatment:
Coolant Change
Requires:
1. Disconnect Battery
2. Loosen off and remove the cap on the header tank (at LHS of radiator)
Also check that the bottom is yellow and rated at 140. If not go to the dealer and get one. (they were subject to a recall years ago as the originals weren’t up to the job)
3. Undo bottom hose from radiator at RHS of the car, let coolant drain (catch it in a bucket and dispose of properly)
4. Undo the 3x 10mm bolts on the thermostat housing (at the front of the engine, in front of the distributor cap) (may need to remove small fuel hose to access one of the top bolts)
5. Remove thermostat, and check its ok (should be closed if cold) If in doubt an new one is £9.99 from GSF/ECP. Bolt housing back together.
6. Insert hose into header tank (at LHS of Radiator) and flush system until water is running clear.
7. Remove top hose (LHS) from radiator and flush through with hose until clear
8. Replace the thermostat, and reattach all hoses
9. Pour the coolant into the header tank (at LHS of radiator) SLOWLY and give it time to settle. (should take about 4.5l to get to cold level marker)
10. Set the heaters to full (HOT and no. 4 fan setting, open all vents) and start car.
11. Let the car idle for 5-10mins keeping an eye on the temp gauge
12. Open the bleed screw (next to the expansion tank cap) WATCH OUT FOR THE COOLANT SPRAYING!!!! (use a cloth to cover it!)
13. Repeat bleeding until all air is out and only water comes out when bleed screw is opened. Top up if required.
14. Get a cup of coffee and relax for 20 mins
Oil Change
Requires:
- Spark Plug Change
- Masking tape + pen
- 19mm Spark plug tool
3. Remove oil filler cap and let car drain for 10mins.(can check how much is left using the dipstick)
Spark plugs
1. Remove the Spark plug leads ONE AT A TIME and (using masking tape + pen) number them 1-4.
[[[Category: Technical]]
