320i
320i
320i SE
Technical
Overall, the 320i is mechanically quite poor. The plus side is that spare parts are cheap, and when things go bang it's a good excuse to upgrade them to 325i equivalents.
  1. Consider fitting a Chip.
  2. Fit a 325i throttle body with 320i modified inlet manifold to keep a reasonable low torque. Don't fit a 325i manifold unless you want all top end power and no pull low down.
  3. Z3 Short shifter conversion
General Info
