M20
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on the intake side of the block, on a machined flat area just above the sump seal. Type number will start 20 ,25 or 27.
Crank Bolt
- M20B20 - 130mm
- M20B25 - 135mm
- M20B27 - 130mm
- M21D25 - 130mm
The 135mm rod weighs 640g.
Crank Pulley
The next version was #1277731 aka the 731. This head was the same as the 200 but featured larger intake ports. It was used in the 320i, 323i and 325e engines.
The heads themselves are not interchangeable; fitting a 731 head to a 325i will result in the valves hitting the pistons, while fitting an 885 head to a 320i will result in the valves hitting the bore lip. 885 heads are therefore completely incompatible with B20 or B23 blocks.
Timing Belt
Head Bolts
| <-- Rear Front --> | ||||||
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Main article: Oil
Oil Pressure Switch
Oil Cooler
Main article: Cooling
Water Pump
Main article: M20 Water Pumps
Thermostat
Expansion Tank
Fan
Rubber Hoses
Prefacelift Cars
Facelift Cars
Drain Plug
Not Starting
Oil Leaks
Cracked Head
Stroker Engines
Engine Management
Exhaust Manifolds
