M20
Revision as of 21:17, 28 March 2013 by Grrrmachine (talk | contribs)
Models
M20 Oil pump and sump gasket
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on the intake side under the cover for the oil pump driveshaft. Type number will start 20 ,25 or 27.
Crank Bolt
  • M20B20 - 130mm
  • M20B25 - 135mm
  • M20B27 - 130mm
  • M21D25 - 130mm
The 135mm rod weighs 640g.
M20 Pistons
Ø: 84 84 84 84 84 84 84
ÜH: 4.2 4.2 4.43 3.6 0.65
MT: -6.2 -5.1 1.1 -3.5 -2
Stroke: 75 75 75 81 81 81 81
Crank Pulley
Cross sectional view of the different M20 heads.
Moulds of M20 inlet ports.
The heads themselves are not interchangeable; fitting a 731 head to a 325i will result in the valves hitting the pistons, while fitting an 885 head to a 320i will result in the valves hitting the bore lip. 885 heads are therefore completely incompatible with B20 or B23 blocks.
However, a 731 head from the 320i can be used on a 325i (and is essential if building a 2.7), by modifying the engine. The recommended method is by profiling the squish band of the head where the pistons protrude. It is important to remember that the 885 head is designed for profiled m20b25 pistons and the 731 head is designed for pistons that are flat at the squish band and do not protrude from the block, if pistons of a different type are used then combustion chamber shape may be compromised resulting in less power, emission issues and detonation.
Head Bolts
12 10 4 2 6 8 14
<-- Rear Front -->
13 7 5 1 3 9 11
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Main article: Oil
Oil Pressure Switch
Oil Cooler
Main article: Cooling
Water Pump
Main article: M20 Water Pumps
Thermostat
Expansion Tank
Fan
Rubber Hoses
Prefacelift Cars
  • Pump to thermostat hose: 11531287651
  • Thermostat to rad hose: 11531708826 or for Jetronic cars 11531278926
  • Bottom rad hose: 11531278925
  • Header tank to pump hose: 11531289257
  • Thermostat to heater: 11531289377
  • Throttle body hose: 13541705568
  • Block to throttle body hose: 13541719976
  • Block to heater hose: 64211380527
Facelift Cars
  • Thermostat to rad hose: 11531722216
  • Bottom rad hose: 11531718980
  • Thermostat to bottom rad hose: 11531718982
  • Thermostat to heater and expansion tank hose: 11531722743
  • Throttle body hose: 13541719966
  • Block to throttle body hose: 13541719967
Drain Plug
Not Starting
Oil Leaks
Cracked Head
Stroker Engines
Engine Management
Exhaust Manifolds
Useful websites
See Also
Engines M21 M30
