Engine Swap - M5x
Revision as of 21:20, 27 February 2013 by Grrrmachine (talk | contribs) (New page: The standard when it comes to non-E30 swap. Whether its the simply grunty 2.5-litre M50 or the beefier 2.8 M52. all aspects are covered of fitting the next generat...)
Parts List
For all swaps, you will need:
  • Full engine with all ancillaries (injectors, MAF, inlet, coil packs, alternator)
  • M5x sump from an E34 (the E36 sump will not fit)
  • Complete engine loom
  • ECU
  • Exhaust
  • M20 Cooling system of radiator inc. brackets, hoses and expansion tank
  • M20 Coding plug for the Instrument cluster
  • New rubber engine and gearbox mounts
  • New rubber prop shaft guibo
  • A mate on standby. An extra pair of hands can save your life.
  • Exhaust system from manifold
  • Flywheel and matching starter motor
  • Gearbox
  • Propshaft
  • Differential
Service Parts
  • Sump Gasket
  • Oil, Fuel and Air filters
  • Spark plugs
  • Engine and Gearbox Oil
  • Gear selector seal
Engine
Mounts
Throttle Cable
By far the simplest gearbox to fit to your M5x conversion is that fitted to the 318iS. This M42-specific gearbox will bolt straight up to the engine and remove the need for any Drivetrain modification such as different differentials. It is also capable of accepting the E36 clutch and flywheel if required, although it is recommended to fit the M20 flywheel.
Propshaft
Combinations
E30 320 gear shift rods If using the M42 box a new M20 spigot bearing is needed (12mm hole)
M52B28 M20 325i M20 325i E36 328i E36 328i Propshaft should be fitted with an E30 centre bearing fitted to the rear section
Exhaust
Off-the-shelf Solutions
DanThe Full manifold and front pipes POI Contact here
1200 inc. VAT http://www.fritzsbits.co.uk/exhausts.htm
Custom Solutions
cast E36 front manifold
325i E30 system
Servo
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
  • exhaust
  • exhaust heat shield (under car)
  • propshaft
  • gear shifter linkage
  • clutch slave
  • rear light switch cable
  • throttle cable
  • coil
  • ECU
Preparation
If you really need to, you can lift the new engine straight out of the donor vehicle and into the recipient. However, if you have the time we strongly recommend you perform the following procedures on the engine prior to fitting:
  1. Replace the sump gasket. These are a weak point on M20 engines and are a real pain to swap in situ.
  3. Remove the exhaust manifold, replace the studs, then refit. Consider having the manifold skimmed for evenness. Be prepared to extract broken studs with a welded-on nut if necessary.
  4. Change the cam belt. Some people forget that M20 engines have a belt rather than a chain, and only learn when the belt breaks, by which time the engine is toast.
  5. Replace the clutch. The donor clutch may be well over 100k miles by now, and due for a replacement.
  6. Replace the alternator belt. Might as well do it now.
  7. Change the gearbox shifter seal. This little bugger is the cause of 99% of gearbox leaks. It takes 5 minutes and 2 pounds to do if the gearbox is off the car. It takes 5 hours if the gearbox has been fitted.
  8. Fit a new distributor cap and rotor. You may have no idea how old the current one is.
Once your engine's hooked up, it really helps to have the back of the car raised substantially because the engine and gearbox combined are very long and need a particular angle of attack to go in. Take your time and go slow. Your aim is to get everything over the front slam panel, then the gearbox output shaft pointing downwards enough to slide into the transmission tunnel. You'll need it to go down while still having the height to get the M20 sump over the slam panel. It helps to have a spare trolley jack to carry the gearbox as it bottoms out; this will help you pull the box into the car as the engine drops down.
  • AFM
  • Oil level switch
  • Idle Control Valve
  • Throttle Position Switch
  • Crank Position Sender
  • Oil Pressure switch
  • Engine earth/body strap - THIS IS ESSENTIAL. Do not crank the engine before fitting this.
