Engine Swap - M5x
Parts List
- Full M5x engine with all ancillaries (injectors, MAF, inlet, coil packs, alternator)
- M5x sump from an E34 (the E36 sump will not fit) inc. oil pickup, dipstick and new gasket. The E38 M52 sump will also work so you can use the complete motor from the E38.
- E36 Engine arms
- E28 M5/535i rubber engine mounts
- Complete engine loom
- ECU
- Gearbox, prop and clutch
- Flywheel and starter
- Exhaust
- Lambda Sensor
- M5x Cooling system inc. hoses
- E36 Aircon radiator inc. 318Ti 80/88 degree radiator temp switch
- E36 Electric fan
- E30 Brown temp sensor
- Renault Clio 2001 Brake Servo
- Differential - dependent on gearbox choice
- New rubber gearbox mounts
- New rubber prop shaft guibo
- Exhaust system from manifold
- Flywheel and matching starter motor
- Gearbox
- Propshaft
- Differential
Service Parts
- Sump Gasket
- Intake Manifold Gasket
- Water pump and Thermostat
- Oil, Fuel and Air filters
- Spark plugs
- Engine and Gearbox Oil
- Gear selector seal
- Renew gear shifter bushes
Engine
Mounts
Throttle Cable
By far the simplest gearbox to fit to your M5x conversion is that fitted to the 318iS. This M42-specific gearbox will bolt straight up to the engine and remove the need for any Drivetrain modification such as different differentials. It is also capable of accepting the E36 clutch and flywheel (single mass only) if required, although it is recommended to fit the M20 flywheel.
The clutch has to match the gearbox you are using. No matter whether it's M5x, M20 or M42, the preferred brand of clutch is Sachs. Make sure that this includes the release bearing.
Propshaft
If you have fitted a more modern M50 or M52 gearbox, then you have one of two choices. Try to buy a used E30 M3 propshaft, or make your own using E36 components. By using the front and rear halves of an E36 325 prop with an E30 centre bearing, you should be able to mate up your new gearbox to your rear diff with the appropriate propshaft length. However, your hybrid prop will need to be handed over to a specialist to ensure it's balanced correctly.
Combinations
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with an E30 centre bearing fitted to the rear section
The M5x family of engines, like all of BMW's six-cylinders, run hot and aren't happy about it. As long as air is flowing through the front radiator everything's fine, but come to a standstill and you'll see the temperature needle creeping steadily upwards.
To cope with that, we need to ensure the M5x is fitted with the appropriate cooling system. This means using an E36 aircon radiator to provide an adequate cooling surface, as well as an electric fan to ensure enough air is blown over it at idle. It is possible to use the viscous fan fitted as standard to an M5x engine, but in an E30 engine bay space is verrrrry tight, and therefore it's more convenient to go with a front-mounted electric alternative.
To guarantee the electric fan kicks in we need a temp sensor from an E36 Ti, which fits into the radiator (which is why it must be the aircon version; there's a mounting boss for the sensor). We'll also need the brown temp sensor from an E30 engine to drive the Instruments, since the existing engine sensor is feeding the ECU.
Water Pump
Since the engine's coming out, now is a perfect time to replace the water pump. M5x engines get hot quickly and a failing water pump can push temps from balmy to critical in a matter of moments.
When swapping the pump, ensure that you use one with a metal impeller; part number 11 51 7 527 799
Thermostat
We highly recommend swapping the thermostat in your car to an 88 degree unit; part number 11 53 7 511 580
While any radiator will do, we strongly recommend an E36 Aircon radiator. This unit will fit between the E30 chassis rails, and provides a mounting boss for our temp sensor.
Fan
M5x engines are fitted with a viscous clutch-driven fan powered from the alternator belt. However, space is very tight and you may find yourself having to trim down the blades to make everything fit in the bay. Rather than messing around, just ditch the viscous and fit an electric alternative; the E36 Electric aircon fan will bolt straight on. For more info, learn about fitting an electric fan.
Temp Switch
Exhaust
| DanThe | Full manifold and front pipes | POI | Contact here |
~1350 plus VAT | http://www.fritzsbits.co.uk/exhausts.htm |
Lambda sensor
M5x engines need to receive a signal from a Lambda, or oxygen, sensor mounted in the exhaust. The M50 uses one sensor, and the M52 uses two. The existing M5x manifolds should include bosses for them to be fitted, so if you're scavenging this from a donor vehicle then make sure you get the lamba sensors too.
Servo
Because of the physical bulk of the M5x, you're not going to have room for your standard brake servo. For that purpose, you need to find a smaller unit that doesn't compromise on braking assistance. While the original swap guides called for the use of a Golf servo, these components are now approaching over 20 years of active duty, so we recommend upgrading to a Renault Clio servo from any car from 2001 onwards (with plastic wings).
The servo may need a slight adjustment - some do, some don't. The trouble is that the rod from the servo to the master cylinder often isn't long enough to make full contact. This leads to a high brake pedal, and binding brakes. While the rod can be twisted to adjust its length, sometimes not enough length is offered, or not enough thread is left on the rod to ensure a firm grip with the servo; this leads to the threads stripping and ruining the servo.
If you find yourself in this scenario, you may just need a spacer. A small bullet of steel up to 20mm in length can be slotted into the receiving end of the master cylinder. That way, the incoming rod from the servo doesn't have to penetrate so far into the master cylinder, and can therefore be screwed down tightly in place and secured with threadlock.
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
- exhaust
- propshaft
- gear shifter linkage
- clutch slave
- rear light switch cable
- throttle cable
- coil
- ECU
Preparation
Unfortunately, you can't just lift the new engine straight out of the donor vehicle and into the recipient. You'll need to take care of a few things first:
- Fit the sump. It should already be in place if you're using an E34 engine, but it's worth whipping it off to change the sump gasket now, as it's near-impossible to do in situ.
- Fit the mounts, although these will be in place if your engine comes from an E36. They bolt into the front mounting holes.
- Remove the exhaust manifold and replace the studs. The original manifold won't fit the E30 anyway, so you might as well remove it now and deal with any broken or rusted studs while the engine's out of the car. Be ready to weld on a nut for any particularly stubborn studs.
- Fit the brown temp sensor from an E30 alongside the existing temp sensor, otherwise your gauges won't work.
- Mate your engine to your chosen gearbox, using the recommended clutch, flywheel and starter.
However, if you have the time we strongly recommend you perform the following procedures on the engine prior to fitting:
- Replace the inlet manifold gasket. These are a weak point on M50 engines.
- Replace the Water_Pump|water pump and thermostat.
Once these critical parts are addressed, the engine is ready to go in. We recommend installing it fully dressed; that means the loom, throttle body and inlet, starter and alternator are already connected. Once the engine is in the bay you won't have much room to play with to install these.
Start with the servo. Unbolt the old one, trial fit the new and make and adjustments (i.e. spacer) as necessary. It will be almost impossible to do this once the M5x is fitted, so set it up properly now. To do so, firstly disconnect the vacuum line going to the inlet. Undo the four bolts from inside the cabin, and release the servo; there is a pin connecting it to the brake rod which needs to be removed. You also need to remove the master cylinder from the servo. Be careful and you can pull it towards the front of the car without removing the brake lines. Installation is equally as straight forward.
Now get under the car. Install your required differential and prop shaft, but don't bolt up the prop shaft centre bearing yet.
You'll want to drop the engine straight in with the gearbox attached and the engine mounts on. The mounting points for the M50 engine are the large visible ring at the front, above the distributor, and a smaller hole at the back of the block, just above the gearbox bell-housing, like so:
Once your engine's hooked up, it really helps to have the back of the car raised substantially because the engine and gearbox combined are very long and need a particular angle of attack to go in. Take your time and go slow. Your aim is to get everything over the front slam panel, then the gearbox output shaft pointing downwards enough to slide into the transmission tunnel. You'll need it to go down while still having the height to get the M5x sump over the slam panel. It helps to have a spare trolley jack to carry the gearbox as it bottoms out; this will also help you pull the box into the car as the engine drops down.
Drop the engine onto its mounts and hand-fit the securing nuts. Use the jack on the gearbox to lift it up while you slide on the prop shaft with the new rubber guibo, then bolt on the gearbox subframe with new rubber mounts. While you're under the car, hook up the gear shifter mechanism and plug in the reversing light switch. When you're sure it's secure, remove the jack and engine hoist.
If you installed the engine "undressed" (that is, without all the ancillaries) then now work your way from the bottom to the top connecting each component. Attach your steering pump and A/C compressor if required.
Start threading through the wiring loom since some wiring needs to go round one side of the engine to the front. Pay attention to how the alternator and starter are wired if you had them disconnected - check here for the starter wiring connections if you're not sure. Feed the ECU plug through the bulkhead, and mount the ECU. Join the engine loom to the car loom at the C101 plug, either directly or with your intermediary loom, but don't connect up the battery terminals yet.
WARNING: It is essential that you check Pin 20 of the C101 plug for a brown wire. On early vehicles, Pin 20 is a brown earth wire, while for some later vehicles Pin 20 is a live, unfused red/yellow wire for the ABS system. CHECK PIN 20 ON BOTH SIDES OF THE C101 PLUG before connecting the battery.
You can then drop your radiator and hoses in to see if any adjustments need to be made.
If you haven't already done so, install the inlet. Connect the rubber intake boot, MAF and air filter. Fit the brake booster hoses to the intake, and make sure you have plugged in the following parts to the loom:
- AFM
- Oil level switch
- Idle Control Valve
- Throttle Position Switch
- Crank Position Sender
- Oil Pressure switch
You can now connect up the exhaust side of things. If you are fabricating your own manifolds then this will be a repeated process of trial and error to make sure everything fits. Don't forget to wire in the lambda sensors.
- Z3 Short Shifter
