Engine Swap - M5x
Revision as of 19:14, 28 February 2013 by Grrrmachine (talk | contribs)
Parts List
  • Exhaust system from manifold
  • Flywheel and matching starter motor
  • Gearbox
  • Propshaft
  • Differential
Service Parts
  • Sump Gasket
  • Oil, Fuel and Air filters
  • Spark plugs
  • Engine and Gearbox Oil
  • Gear selector seal
Engine
Mounts
Throttle Cable
By far the simplest gearbox to fit to your M5x conversion is that fitted to the 318iS. This M42-specific gearbox will bolt straight up to the engine and remove the need for any Drivetrain modification such as different differentials. It is also capable of accepting the E36 clutch and flywheel if required, although it is recommended to fit the M20 flywheel.
The clutch has to match the gearbox you are using. No matter whether it's M5x, M20 or M42, the preferred brand of clutch is Sachs. Make sure that this includes the release bearing.
Propshaft
If you have fitted a more modern M50 or M52 gearbox, then you have one of two choices. Try to buy a used E30 M3 propshaft, or make your own using E36 components. By using the front and rear halves of an E36 325 prop with an E30 centre bearing, you should be able to mate up your new gearbox to your rear diff with the appropriate propshaft length. However, your hybrid prop will need to be handed over to a specialist to ensure it's balanced correctly.
Combinations
E30 320 gear shift rods If using the M42 box a new M20 spigot bearing is needed (12mm hole)
M52B28 M20 325i M20 325i E36 328i E36 328i Propshaft should be fitted with an E30 centre bearing fitted to the rear section
The M5x family of engines, like all of BMW's six-cylinders, run hot and aren't happy about it. As long as air is flowing through the front radiator everything's fine, but come to a standstill and you'll see the temperature needle creeping steadily upwards.
To cope with that, we need to ensure the M5x is fitted with the appropriate cooling system. This means using an E36 aircon radiator to provide an adequate cooling surface, as well as an electric fan to ensure enough air is blown over it at idle. It is possible to use the viscous fan fitted as standard to an M5x engine, but in an E30 engine bay space is verrrrry tight, and therefore it's more convenient to go with a front-mounted electric alternative.
To guarantee the electric fan kicks in we need a temp sensor from an E36 Ti, which fits into the radiator (which is why it must be the aircon version; there's a mounting boss for the sensor). We'll also need the brown temp sensor from an E30 engine to drive the Instruments, since the existing engine sensor is feeding the ECU.
While any radiator will do, we strongly recommend an E36 Aircon radiator. This unit will fit between the E30 chassis rails, and provides a mounting boss for our temp sensor.
Fan
M5x engines are fitted with a viscous clutch-driven fan powered from the alternator belt. However, space is very tight and you may find yourself having to trim down the blades to make everything fit in the bay. Rather than messing around, just ditch the viscous and fit an electric alternative; the E36 Electric aircon fan will bolt straight on.
Temp Switch
Exhaust
Off-the-shelf Solutions
DanThe Full manifold and front pipes POI Contact here
1200 inc. VAT http://www.fritzsbits.co.uk/exhausts.htm
Custom Solutions
cast E36 front manifold
325i E30 system
Lambda sensor
M5x engines need to receive a signal from a Lambda, or oxygen, sensor mounted in the exhaust. The existing M5x manifold should include a boss for one to be fitted, so if you're scavenging this from a donor vehicle then make sure you get the lamba too.
Servo
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
  • exhaust
  • exhaust heat shield (under car)
  • propshaft
  • gear shifter linkage
  • clutch slave
  • rear light switch cable
  • throttle cable
  • coil
  • ECU
Preparation
If you really need to, you can lift the new engine straight out of the donor vehicle and into the recipient. However, if you have the time we strongly recommend you perform the following procedures on the engine prior to fitting:
  1. Replace the sump gasket. These are a weak point on M20 engines and are a real pain to swap in situ.
  3. Remove the exhaust manifold, replace the studs, then refit. Consider having the manifold skimmed for evenness. Be prepared to extract broken studs with a welded-on nut if necessary.
  4. Change the cam belt. Some people forget that M20 engines have a belt rather than a chain, and only learn when the belt breaks, by which time the engine is toast.
  5. Replace the clutch. The donor clutch may be well over 100k miles by now, and due for a replacement.
  6. Replace the alternator belt. Might as well do it now.
  7. Change the gearbox shifter seal. This little bugger is the cause of 99% of gearbox leaks. It takes 5 minutes and 2 pounds to do if the gearbox is off the car. It takes 5 hours if the gearbox has been fitted.
  8. Fit a new distributor cap and rotor. You may have no idea how old the current one is.
Once your engine's hooked up, it really helps to have the back of the car raised substantially because the engine and gearbox combined are very long and need a particular angle of attack to go in. Take your time and go slow. Your aim is to get everything over the front slam panel, then the gearbox output shaft pointing downwards enough to slide into the transmission tunnel. You'll need it to go down while still having the height to get the M20 sump over the slam panel. It helps to have a spare trolley jack to carry the gearbox as it bottoms out; this will help you pull the box into the car as the engine drops down.
  • AFM
  • Oil level switch
  • Idle Control Valve
  • Throttle Position Switch
  • Crank Position Sender
  • Oil Pressure switch
  • Engine earth/body strap - THIS IS ESSENTIAL. Do not crank the engine before fitting this.
