Engine Swap - M20
Parts List
For all swaps, you will need:
- Full engine with all ancillaries (injectors, AFM, coil, alternator, engine mounts, starter motor and flywheel)
- Complete engine loom
- ECU
- Complete exhaust from manifold to back box
- M20 Cooling system of radiator inc. brackets, hoses and expansion tank
- New rubber engine and gearbox mounts
- New rubber prop shaft guibo
- M20 Gearbox.
Service Parts
- Sump Gasket
- Oil, Fuel and Air filters
- Spark plugs
- Distributor cap and rotor
- Engine and Gearbox Oil
- Gear selector seal
Engine
Prop
- 3.91 - Spirited driving, but quite high revs at motorway speeds which can be tiring and noisy
- 3.73 - Good all-rounder
- 3.64 - The cruising ratio, which helps claw back valuable fuel economy from the thirsty M20 engine.
- Cutting off both C101 connectors and joining the wires directly.
- Cut the plug off your old engine loom and join it to your new one.
- Get a new C101 plug for your car loom and fit that
- Make an intermediary loom to fit between your car and engine looms, using new and old style plugs at either end
Either of these expansion tanks will need to have a bracket fitted to hold it. If you don't want to do any welding and you aren't happy drilling holes in your car to use ordinary bolts, there is a third solution; a 318iS radiator, which has an expansion tank on the side. You'll just need to get creative with your cooling hoses to make sure it's all plumbed in correctly.
Finally, your radiator is held in place on plastic mounts which clip into holes on the chassis rails. These mounts will be different to your existing radiator mounts, and need to be sourced. They are two different sizes; one short, one long. There have been reports that various radiators don't fit these mounts despite being sold as Genuine BMW radiators, so prepare to be creative with your mounting arrangement, or source another radiator.
Exhaust
Brackets
Depending on your E30, there may be three mounting points that need fettling in order to mount all of your M20 parts. These are
- Relay bracket - 41141904837
- Expansion tank mount - 41141871979
- AFM mount - 41141913049
- exhaust
- propshaft
- gear shifter linkage
- clutch slave
- rear light switch cable
- throttle cable
- coil
- ECU
Preparation
If you really need to, you can lift the new engine straight out of the donor vehicle and into the recipient. However, if you have the time we strongly recommend you perform the following procedures on the engine prior to fitting:
- Replace the sump gasket. These are a weak point on M20 engines and are a real pain to swap in situ.
- Remove the exhaust manifold, replace the studs, then refit. Consider having the manifold skimmed for evenness. Be prepared to extract broken studs with a welded-on nut if necessary.
- Change the cam belt. Some people forget that M20 engines have a belt rather than a chain, and only learn when the belt breaks, by which time the engine is toast.
- Replace the clutch. The donor clutch may be well over 100k miles by now, and due for a replacement.
- Fit a new distributor cap and rotor. You may have no idea how old the current one is.
Once your engine's hooked up, it really helps to have the back of the car raised substantially because the engine and gearbox combined are very long and need a particular angle of attack to go in. Take your time and go slow. Your aim is to get everything over the front slam panel, then the gearbox output shaft pointing downwards enough to slide into the transmission tunnel. You'll need it to go down while still having the height to get the M20 sump over the slam panel. It helps to have a spare trolley jack to carry the gearbox as it bottoms out; this will help you pull the box into the car as the engine drops down.
- AFM
- Oil level switch
- Idle Control Valve
- Throttle Position Switch
- Crank Position Sender
- Oil Pressure switch
- Z3 Short Shifter
- Fit a Chip
