M5x
Revision as of 16:18, 20 November 2011 by Grrrmachine (talk | contribs)
M50
M50 engines weigh 138kg
Engine Displacement Power Torque Redline Bore Stroke Year
M50B20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 6000 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1991
M50B25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 6000 245 N·m (181 ft·lbf) @ 4700 6500 84mm 75mm 1991
M50TU
M50TUB20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1993
M50TUB25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 5900 250 N·m (184 ft·lbf) @ 4200 6500 84mm 75mm 1993
M52
M52 engines weigh 118kg
M52B20 2.0 L (1990 cc/121 in³) 110 kW (148 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6500 80mm 66mm 1994
M52B25 2.5 L (2494 cc/152 in³) 123 kW (170 hp) @ 5500 245 N·m (181 ft·lbf) @ 3950 6500 84mm 75mm 1995
M52B28 2.8 L (2793 cc/170 in³) 142 kW (193 hp) @ 5300 280 N·m (207 ft·lbf) @ 3950 6500 84mm 84mm 1995
M52TU
M52TUB20 2.0 L (1990 cc/121 in³) 110 kW (148 hp) @ 5900 190 N·m (140 ft·lbf) @ 3500 6500 80mm 66mm 1998
M52TUB25 2.5 L (2494 cc/152 in³) 123 kW (170 hp) @ 5500 245 N·m (181 ft·lbf) @ 3500 6500 84mm 75mm 1998
M52TUB28 2.8 L (2793 cc/170 in³) 142 kW (193 hp) @ 5500 280 N·m (207 ft·lbf) @ 3500 6500 84mm 84mm 1998
E34 Sump with baffle plate
Sump Gasket
M5x Pistons
M50B20 10.5:1 M50B25 10:1 M50TUB25 10.5:1 M52B20 11:1 M52B25 10.5:1 M52B28 10.2:1
Piston: 0827300 0827100 0831900 0830400 0830900 0830700
Ø: 80 84 84 80 84 84
KH: 42.8 38.2 32.55 31.7 32.7 31.82
GL: 62.8 63.2 50.05 51.3 52.7 51.85
BO: 22.0 x 54 22.0 x 54 22.0 x 54 22.0 x 51 22.0 x 56 22.0 x 59
Stroke: 66 75 75 66 75 84
Conrod Length: 135 135 140 135 135 135
Volume 1989 2493 2493 1990 2493 2792
Piston Shape: 2572.jpg 0827100.jpg 0830700.jpg 0830400.jpg 0830900.jpg 0830700.jpg
Crank Pulley
The non-VANOS head, as fitted to the first M50 engines, is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a relatively high compression ratio. These heads use double valve springs as standard, and a high valve duration of 240 degrees.
Rocker covers were available in plastic or aluminium.
Physically, the covers on these engines are interchangeable, but the cover on top is specific to M50 and M52 engines for a number of reasons.
Primary of these is the engine diagnostics plug. The M50 engine used the first generation diagnostic system known as OBD I, while the M52 used the industry-standard OBD II. The spark plug coils used in the engine are specific to these systems, so something as simple as a cover necessitates a whole changeover of ignition components, which just isn't worth it.
Secondly, plumbing for the crankcase breather hose is different between the engines, so re-working some pipes would be needed.
Finally, Double-VANOS covers are specific to those engines.
Inlet Cam
Exhaust Cam
Lifters
VANOS
Main article: VANOS
VANOS is a variable-valve timing system that determines how long each valve stays open for. Before VANOS, each camshaft was locked into a fixed rotation based on the crank; as the crank turned, so would the cam shafts.
VANOS changed all this by introducing a gearing system which could slow down or speed up exactly when the valves opened, depending on crankshaft position. By installing this gearing mechanism at the front of the camshaft, the opening of the valves could be better co-ordinated to the engine speed, so that a faster-spinning engine can suck in air earlier on each stroke. The time between the intake closing and the exhaust opening is known as Cam-Phasing.
On early VANOS engines, this phasing was a basic switch, giving an ON-OFF characteristic. The engine was either on its idle timing, or its power timing, and the gear system would turn on or off depending on the ECU.
With Double-VANOS, this gearing system was applied to the exhaust cam too, allowing all sorts of clever overlaps regarding when the intake closed and the exhaust opened. The more the overlap, the more efficient the engine.
The actual gearing is a mixture of electric solenoids and hydraulic pressure, and the oil seals in these hydraulic systems are a known issue. If you ask BMW to repair it, they will replace the entire system, but oil seals are available separately and can be fitted with the right tools.
Inlet
Main article: M5x Inlet
M50B20 and M50B25 inlets
The main difference between the 325 and 328 inlet is the plastic manifold and the size of the ports in it. This manifold is 10mm greater (width) in port size over the standard 328. The 325 has 55x25mm port's and the 328 has 45x25mm port size. This equates to a much bigger flow rate; the 325 inlet will flow 50% more than the 328.
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
Engine Mounts
Exhaust
Off-the-shelf Solutions
DanThe Full manifold and front pipes POI Contact here
1200 inc. VAT http://www.fritzsbits.co.uk/exhausts.htm
Custom Solutions
cast E36 front manifold
325i E30 system
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its back, or the M42 flywheel.
By far the simplest gearbox to fit to your M5x conversion is that fitted to the 318iS. This M42-specific gearbox will bolt straight up to the engine and remove the need for any Drivetrain modification such as different differentials. It is also capable of accepting the E36 clutch and flywheel if required, although it is recommended to fit the M20 flywheel.
Propshaft
Combinations
E30 320 gear shift rods If using the M42 box a new M20 spigot bearing is needed (12mm hole)
M52B28 M20 325i M20 325i E36 328i E36 328i Propshaft should be fitted with an E30 centre bearing fitted to the rear section
Throttle Cable
Not Turning Over
Not Starting
Overheating
VANOS Chatter
Useful websites
See also
