Technical
Engines
| Name | Volume | Engine | Valvetrain | Fuel | Output | Torque | Engine code | Years |
| 316 | 1766cc | 4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 316i | 1596cc | 4cyl | SOHC 8V | Petrol | 102hp (75kW) @4500 rpm | 105ft/lb (140Nm) @4250 rpm | M40B16 | 1988–1995 |
| 318 | 1766cc | 4cyl | SOHC 8V | Petrol | 104hp (77kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 318i | 1796cc | 4cyl | SOHC 8V | Petrol | 113hp (85kW) @4500 rpm | 122ft/lb (165Nm) @4250 rpm | M40B18 | 1987–1995 |
| 318iS | 1766cc | 4cyl | SOHC 8V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | M42B18 | 1989–1991 |
| 320i | 1990cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @5800 rpm | 125ft/lb (170Nm) @4000 rpm | M20B20 | 1982–1985 |
| 320i | 1990cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @6000 rpm | 120ft/lb (164Nm) @4300 rpm | M20B20 | 1985–1991 |
| 320iS | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @6750 rpm | 155ft/lb (210Nm) @4750 rpm | S14 | 1982–1990 |
| 323i | 2316cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4000 rpm | M20B23 | 1982–19850 |
| 325e | 2693cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4250 rpm | 169ft/lb (230Nm) @3200 rpm | M20B27 | 1982–1990 |
| 325i | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| 325iX | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1986–1988 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 212hp (158kW) @6750 rpm | 170ft/lb (0Nm) @4600 rpm | S14 | 1989–1991 |
| M3 Evolution | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1987–1987 |
| M3 Evolution II | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @6750 rpm | 181ft/lb (0Nm) @4750 rpm | S14 | 1988–1988 |
| M3 Sport Evolution | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @6750 rpm | 177ft/lb (0Nm) @4750 rpm | S14 | 1990–1990 |
| 324d | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | M21D24 | 1985–1993 |
| 324td | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | M21D24 | 1985–1993 |
Maintenance
Engine Swaps
Maintenance
A Z3_short_shifter_conversion will help you change gears quicker.
The following were fitted to each E30:
It was possible to order a Limited_Slip_Differential from the factory, with the ratio suitable for the engine in your car.
Maintenance
The differential will require an oil change every now and then. Small-case diffs take 0.9 litres, medium-case diffs require 1.7 litres.
Changing the differential will do one of two things. Fitting a lower differential will give better fuel economy at cruising speeds, at the cost of reduced acceleration. Fitting a higher differential will get you away from the traffic lights quicker, but will make your engine rev that much higher on the motorway, with the noise and fuel bills that go with it.
For more information on the E30 braking system, check the Brakes.
Maintenance
If needed, E30 brakes can be improved in a number of ways. While some choose to upgrade to rear discs, others prefer to use bigger discs and callipers from newer BMWs, which necessitates an upgrade to a 5-bolt hub.
Maintenance
Steering
Maintenance
The steering system is relatively simple on an E30, and as such the main requirements are to keep the rack in good condition and topped up with fluids. Changing the fluid regularly will keep the rack clean, but you must also pay attention to the track rod ends
While the steering of an E30 is a charm of feedback-response, neither too heavy or too light, many of the more spirited drivers find the standard rack too long, in the sense that it takes too many turns from one full lock to the other. Fitting a faster rack from a BMW Z3 is a common and simple upgrade, but for those looking for bigger increases, fitting a rack from an E36 M3 can bring dramatic improvements.
Body Styles and Fittings
The E30 was offered in a number of body styles. A 2-door and 4-door Saloon, Cabriolet and Touring
Maintenance
Electrical
The E30 loom is a monstrous labyrinth of wires, all colour-coded, so that you can easily trace exactly which wire does what. All wires inside the cabin are part of a one-piece loom that runs through the bulkhead on the passenger side of UK cars, where they meet the Fuse Box.
Maintenance
Ensuring that all the fuses in your Fuse Box are the correct rating is essential in preventing electrical fires. If you are experiencing blown fuses, DO NOT insert a fuse with a higher rating than that in the diagram.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
| First Column Header | Second Column Header | Third Column Header |
| We | Love | E30s |
| Old | Skool | Cool |
