Steering Rack Conversions
Parts
  • New Rack
  • Rack spacers (14mm)
  • Inner and outer tie rods (complete set of either E30 or E36, but not E46)
  • Steering linkage (click here for more info)
  • New aluminium crush washers (14mm and 16mm)
Tools
  • Ball-joint splitter
  • 13mm, 15mm, 17mm, 19mm and 22mm sockets or spanners
  • A hammer and crowbar or suitable drift
Which Rack?
Rack Part Number Turns
(lock to lock)
Comments
E30 4 Standard power steering rack for all models
E36 3.4 An adequate replacement for the E30. Nothing sporty, but certainly livelier than what the E30 left the factory with.
E36 M3 ('95) 3.0 Don't let the low lock-to-lock fool you. This rack is a variable speed unitm meaning it's ponderous in the middle and only rapid when it's close to full lock. In effect, this is the slowest of the E36 racks, and best avoided.
E36 M3 Evo ('96-) 3.2 Despite the lock-to-lock number, the E36 M3 rack isn't any faster than a standard E36 rack; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack.
E46 3.2 A very good compromise between the older E36 rack and the wicked-sharp Z3. Cheap and plentiful too, but try getting a Clubsport rack if you can.
E46 Clubsport 6 755 067 3 The most popular choice these days, thanks to its speed and availability. Fitted to a range of E46s - look for the purple tag.
Z3 3213 1094038
3213 1095577
2.7 The fastest rack, and no need for a custom steering linkage, makes this the perfect rack. But most are now well over 20 years old, so finding a good one is increasingly difficult.
Steering Linkage
E36 hybrid
Now, back to the hole in the disc. This is for the centering bush (similar to the nylon one on the E30 joint). If you look at the pinch bolt section you removed earlier, you should see a bronze bush in the centre. This is retained by some deformations (stakes ?) in the housing. With some careful drill work, the bush can be removed. It also helps if you cut through the side of the housing and open it up with a chisel. You need to make the hole in the centre of your new metal disc the same as the O/D of the bush. It needs to be a snug fit, and can be retained with some bearing securing solution (Loctite etc).
Ready-made
DanThe's steering linkage
Guibo Delete
Opel Corsa C
Rack
Rack mounted in the NON-PAS position
Spacers placed between top of rack and subframe
Pipes
Track Rods
Modified E36 inner rod with thread venting suitable for use in E46 rack
If you're considering an E46 Clubman (purple tag) rack, keep in mind the stock inner rods use vented threads to bleed air pressure between left and right boots when the wheel is turned. Therefore, you need to pair E46 inners with E36 outers. Alternatively, you can get crafty with a bench drill and modify a pair of E36 inners to have the same thread venting. E30 outers won't work here as they connect to the inner rod using a male thread. E46 inners and outers combined are (anecdotally), too wide for the E30.
Finishing
Complications
318iS plastic under-tray modified for rack fitment.
