Limited Slip Differential
Case sizes
Ratios
  • 3.15 - M3
  • 3.64 - prefacelft 325i
  • 3.73 - facelift 325i
  • 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport
  • 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case.
  • 4.27 -
  • 4.44 -
Identification
To identify an LSD one can first check for the presence of the tag on the rear casing. The ratio on this will be prefixed with an S for LSDs.
Oil
