Engines
Revision as of 16:42, 17 February 2013 by Grrrmachine (talk | contribs)
List of Engines
316 M10B18 1766cc 4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm 1982–1987
316i M40B16 1596cc 4cyl SOHC 8V Petrol 102hp (75kW) @4500 rpm 105ft/lb (140Nm) @4250 rpm 1987–1994
318i M10B18
M40B18
1766cc
1796cc
113hp (85kW) @4500 rpm
122ft/lb (165Nm) @4250 rpm
1982–1990
1987–1995
318iS M42B18 1766cc 4cyl DOHC 16V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm 1989–1991
127hp (95kW) @6000 rpm
125ft/lb (170Nm) @4000 rpm
120ft/lb (164Nm) @4300 rpm
1982–1985
1985–1991
212hp (158kW) @6750 rpm
176ft/lb (0Nm) @4750 rpm
170ft/lb (0Nm) @4600 rpm
1986–1988
1989–1991
Special engines
Ancillaries
Fuel
Main article: Fuel
Air
Main article: Intake
Spark
Main article: Ignition
Starter
Main article: Starter
Your petrol motor needs an electric motor to get it started. This motor spins the engine up to the speed needed for normal combustion to work - once those are happening, the starter will disengage.
The starter for all E30 engines sits on the intake side of the engine, and is bolted to the gearbox. It has direct heavy-duty wiring to the alternator and battery, and grounds through the engine block to the car chassis. It is triggered by wiring directly from the ignition switch.
Starters are specific to each engine, because the gear teeth of the starter cog has to match the teeth on the engine flywheel. What's more, there is a difference between early and late M20 starters due to a change in flywheel in 1987.
Exhaust
Main article: Exhaust
Engine Management
Main article: Cooling
Oil
Main article: Oil
Engine Swaps
Main article: Engine Swaps
Aside from swapping between engines within the E30 line-up, the following BMW engines have also proved to fit under the bonnet:
Troubleshooting
