Bodywork
Revision as of 17:51, 18 January 2016 by Willnz (talk | contribs)
Shell
Roof
Main article: Roof
Panels
Bumpers
Paint
Main article: Paint Codes
The E30 was offered in a number of colours during its lifetime, in both solid and metallic paint. Some are unique to early cars, others were only available to facelift models.
The colour of your car will be printed on a sticker on your front passenger suspension turret.
Windows
Windscreen
Door windows
Main article: Door windows
If your windows aren't lining up properly, learn how to align the door windows.
Quarterglass
Trim
Chrome and Shadowline
Front Grille
Badges
Pinstripes
BMW offered the option of having pinstripes fitted when buying your E30. These run the length of the body just above the coachline. On these pinstripes, the upper one is 3mm thick, the lower one 2mm thick, a 2mm gap between. Dependent on the colour of the car affected what colour pinstripes BMW offered, here's a list of those combinations.
There were also the stripe kits offered by the likes of Alpina, Hartge and AC Schnitzer.
Body Kits
Main article: Body Kits
Maintenance
Problems
Rust
Main article: Rust
