Fitting Tech2 front and rear bumpers
The ultra-desirable 325i Sport came fitted with a special M-Tech body kit as standard. Part of the M-Tech package, it wasn't exclusive to that model; lesser E30 models could be fitted with the same kit... if the owner had the cash. The kits were specific to pre- and post-facelift, with the M-Tech 2 kit being fitted to models after 1987.
If you've got your grubby mitts on one of these kits, here's how to bolt it onto your E30.
NOTE: It is not worth attempting to fit a Tech 2 kit to a car from 1987 or earlier. Significant cutting and welding is needed, and the result always looks butchered.
The official BMW fitting guide is available here
Seems to be a lot of confusion about fitting the M-Tech 2 bumpers and valances to a standard facelift car. It is actually relatively easy to do and requires only some minor drilling and purchasing of clips. All face lift cars can accept the Tech 2 front and rear bumpers including 4 door, touring, coupe and cabriolets. Pre facelift cars require fairly extensive modifications to the metal valance, tow eye, front and rear bumper mounts, rear bumper/wheel arch mating location etc. There are separate sites describing this job, a PM to mrLEE30 and I will send the link. I am not a fan of the M-Tech side skirts so I did not fit them, however the fitting guide is available here.
Note that the Tech 2 sill/door covers are specific to each body style; Saloon, Touring and Cabriolet. This article does not cover any of this, only the bumpers and valances.
Read the whole article first before you star. For the drilling there is a template available for this (51712239841), I didn’t have one so I shall explain how I did it.
Tools and parts
M-Tech 2 front bumper, front M-Tech valance, rear M-Tech bumper. Try if possible to ensure the tow eye/fitting hardware covers are with it (2 on the rear, 2 on the front) and the front left and right brake air ducts are included as they are Tech 2 specific items too, and if you don’t already have front fog lights you will need these to finish the look off.
Front Bumper
No. Part Part Number Quantity
3 Lower valance clip 51712239711 7
4 Expanding rivet 17111712963 8
5 Side clips 51711033719 2
6 Side clips 51711922599 2
7 Plastic nut 16131176747 2
Rear Bumper
11 Guide Left 51122239847 1
11 Guide Right 51122239848 1
12 Grommet 51711939303 2
13 Rivet 51711936929 2
Tools
  • Screwdrivers
  • 8mm,10mm, 13mm socket set/spanners
  • T-55 Torx socket
  • Ratchet drive (1/2 inch or bigger)
  • Ruler/tape measure
  • punch and hammer
  • Drill
  • 4mm and 8mm metal drill bits
  • WD40 or similar
  • red oxide paint
  • paint for priming (grey)
  • Black silicone
  • Axle stands or an inspection pit
  • A mate
Rear Bumper and Valance
The M-Tech 2 rear bumper is a one piece part with bumper and valance as one. If someone has this as a two piece it is a Tech1 item. Below you can see the rear bumper/valance in the foreground, and in the background you can see the tech 2 bumper and lower valance.
Front Bumper and Valance
The M-Tech front bumper and valance are two separate pieces. The bumper mounts on the existing mountings and the valance requires some clips to be fitted to the existing metal valance. Where I mention valance in the article I mean the tech 2 fibre glass valance, if I say metal valance I mean the one on your car.
The side clips…on my tech2 valance the brackets that hold these clips were broken so I could not fit them without a load of messing about, I used black silicone applied from the inside to hold this part to the metal valance. If your brackets are ok then I would recommend fitting these, the technique is the same, mock up the lower valance with the clip and fixing bolt in place, measure where the holes are required for each side, drill, paint and check its right, do not fix it at this point.
Now fit the front bumper, clean and oil the side mountings, use a mate and fit the bumper as a trial first keeping it straight. Check for alignment. The front bumper has 4 adjustable mounting points, the two side mounting can be moved up, down, left and right, to get to the fixing bolts/screws you must get up underneath the front wing, it may be necessary to remove the horn on one side to get access. Adjust these as required and re tighten. The front two centre bumper mounts can also be adjusted. They are held on with two 13mm bolts, which can be loosened from the front and the mounts can be adjusted as required. My suggestion would be to leave these and try to adjust from the side mountings first, if that fails then try the centre mounts. Once happy refit the bumper, plug in the indicator supply and refit the Torx bolts and tighten.
Now refit the fog lights and M-Tech2 brake cooling ducts, and if you want to the plastic central air intake cover.
That it, job done!!
Written by Mrlee
