Body Kits
Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
AV3
| Description | Available as an aftermarket extra from Autovogue. Essentially a copy of the kit fitted to the E36 M3 | ||
| Features | Fitting | Picture | |
| Front Valance | 140px | ||
| Skirts | |||
| Rear Valance | 140px | ||
Breyton
| Description | Available as an aftermarket extra from Breyton | ||
| Front Valance | |||
| Skirts | |||
| Rear Valance | |||
Hartge H23/H28
| Description | Fitted to the pre-facelift Hartge model H23 and the 323i-powered H26 | ||
| Front Valance | |||
| Rear Valance | |||
Hartge H26/H27
| Description | Fitted to the facelifted Hartge models; the 325i-powered H26 and the M30-powered H27 | ||
| Front Valance | |||
| Skirts | |||
| Rear Valance | |||
Racing Dynamics
| Description | Available as an aftermarket extra from Racing Dynamics | ||
| Front Valance | |||
| Skirts | 140px | ||
| Rear Valance | |||
Reiger GTS
Tech 1
| Description | Fitted to the pre-facelift 325i Sport in 1987, as well as the 333i. | ||
| Front Bumper/Valance | The Tech 1 metal bumper and plastic valance are sperate parts. | ||
| Skirts | |||
| Rear Bumper | Just like the front, the rear bumper is separate from its valance. | ||
| Spoiler | |||
Tech 2
| Description | Fitted to the facelifted 325i Sport in 1988-1991. | ||
| Front Bumper | Fitting Guide | ||
| Front Valance | Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling. | ||
| Skirts | 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. | ||
| Rear Bumper/Valance | The Tech 2 rear bumper and valance are a one-part component. | Fitting Guide | |
Zender
| Description | Available as an aftermarket extra from Zender | ||
| Front Valance | |||
| Skirts | |||
| Rear Valance | |||
| Boot Spoiler | |||
Front Valances
The valance is the metal panel running behind and underneath the bumper on E30s, and is the key distinguishing feature between pre- and facelift cars. Because of that re-design, all the major body kit manufacturers listed above ran two versions of their valances, to accommodate the differences.
The differing styles took into account mounting for fog lights, air flow to the brakes and oil cooling, and the concept of combined units that incorporated both a chin spoiler and bumper into one unit.
| Name | Fitted To | Features | Fitting | Picture |
| Alpina Type 147 | The early Alpina valance was fitted to the range of Alpina models running up to 1987. | |||
| Alpina Type 159 | For plastic-bumpered Alpina cars with no A/C | |||
| BBS | For pre-facelift vehicles. | Has the earlier shape bumper mount holes, making it exclusive to early vehicles. |
Lips
Side Skirts
| SE Skirts | The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. | Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
The kit is mounted using a series of plastic clips. Along the top edge, these clips plug into holes drilled into the sill, while the bottom edge clips directly to the lower sill edge. As the skirt tucks into the wheel arch at both ends, two more holes are drilled into the wheel arch lip to hold plastic plugs. |
Fitting Guide | 140px |
Boot Spoilers
Boot Spoilers
Start by finding the centre line of the boot lid. Measure out from here 565mm, 346mm and 118mm to the left, and 130mm, 346mm and 565mm to the right.
The distance forward for the holes is measured from the lower edge of the boot, up and around the curved bit. The measurements are, in the same order as the measurements I've already given, 125mm, 127mm, 129mm, 129mm, 127mm and 125mm. Hole diameter is 7.5mm.
