M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
Sump Gasket
Crank Pulley
The M50 head is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a higher compression ratio than the M52.
Inlet Cam
Exhaust Cam
VANOS
Main article: VANOS
Rocker Arms
Inlet
Main article: M5x Inlet
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
Engine Mounts
Exhaust
| DanThe | Full manifold and front pipes | POI | Contact here |
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its back, or the M42 flywheel.
Propshaft
Combinations
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with an E30 centre bearing fitted to the rear section
Throttle Cable
Not Turning Over
Not Starting
Overheating
VANOS Chatter
