M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
Sump Gasket
While the physical design makes all crankshafts interchangeable between M5x engines, there are some subtle differences in the size and angle of the lobes lobes.
The rod lengths for M5x engines are as follows:
- M50B25 - 135 mm (non VANOS engine)
- M50B25TU - 140 mm
- M52B25 - 135 mm
- M52B28 - 135 mm
Crank Pulley
The M50 head is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a higher compression ratio than the M52.
Inlet Cam
Exhaust Cam
VANOS
Main article: VANOS
Rocker Arms
Inlet
Main article: M5x Inlet
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
Engine Mounts
Exhaust
| DanThe | Full manifold and front pipes | POI | Contact here |
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its back, or the M42 flywheel.
Propshaft
Combinations
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with an E30 centre bearing fitted to the rear section
Throttle Cable
Not Turning Over
Not Starting
Overheating
VANOS Chatter
