M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed. However, there are key differences between the two, and an M52 pump cannot be fitted to an M50 engine.
Sump Gasket
While the physical design makes all crankshafts interchangeable between M5x engines, there are some subtle differences in the size and angle of the lobes lobes.
The rod lengths for M5x engines are as follows:
- M50B25 - 135 mm (non VANOS engine)
- M50B25TU - 140 mm
- M52B25 - 135 mm
- M52B28 - 135 mm
Crank Pulley
The M50 head is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a higher compression ratio than the M52.
Inlet Cam
Exhaust Cam
Non-Vanos valves, such as those fitted to the M50B20 and B25, are double-sprung. Their valve stems are also thicker than their VANOS counterparts, being
7mm rather than 6mm, making them better able to tolerate increases in power and torque.
VANOS
Main article: VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
Engine Mounts
Exhaust
| DanThe | Full manifold and front pipes | Contact here | |
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its face, or the M42 flywheel.
Despite the work involved, most experienced swappers recommend the use of the M20 flywheel. The existing dual-mass wheel is not only extremely heavy but also problematic, and ties you to a gearbox with worse-performing ratios than its M20 counterparts.
Propshaft
Combinations
E30 320 gear shift rods Ff using the M42 box a new M20 spigot bearing is needed (12mm hole) |
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with a reversed E30 centre bearing
Throttle Cable
Not Turning Over
This is a common problem for those engines fitted with the M20 flywheel. The lip of the flywheel will either be catching on the block where the long rear sump bolts come home, or the bolts that hold the flywheel onto the crank will be too long.
The solution to this is either to grind away a small section of the sump (not recommended), or have the flywheel lightened by removing part of the lip. Either way, the engine and gearbox will have to come out of the engine to cure the problem.
Not Starting
Overheating
VANOS Chatter
