M5x
Revision as of 12:13, 18 November 2011 by Grrrmachine (talk | contribs)
M50
M50 engines weigh 138kg
Engine Displacement Power Torque Redline Bore Stroke Year
M50B20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 6000 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1991
M50B25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 6000 245 N·m (181 ft·lbf) @ 4700 6500 84mm 75mm 1991
M50TU
M50TUB20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1993
M50TUB25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 5900 250 N·m (184 ft·lbf) @ 4200 6500 84mm 75mm 1993
M52
M52 engines weigh 118kg
M52B20 2.0 L (1990 cc/121 in³) 110 kW (148 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6500 80mm 66mm 1994
M52B25 2.5 L (2494 cc/152 in³) 123 kW (170 hp) @ 5500 245 N·m (181 ft·lbf) @ 3950 6500 84mm 75mm 1995
M52B28 2.8 L (2793 cc/170 in³) 142 kW (193 hp) @ 5300 280 N·m (207 ft·lbf) @ 3950 6500 84mm 84mm 1995
M52TU
M52TUB20 2.0 L (1990 cc/121 in³) 110 kW (148 hp) @ 5900 190 N·m (140 ft·lbf) @ 3500 6500 80mm 66mm 1998
M52TUB25 2.5 L (2494 cc/152 in³) 123 kW (170 hp) @ 5500 245 N·m (181 ft·lbf) @ 3500 6500 84mm 75mm 1998
M52TUB28 2.8 L (2793 cc/170 in³) 142 kW (193 hp) @ 5500 280 N·m (207 ft·lbf) @ 3500 6500 84mm 84mm 1998
E34 Sump with baffle plate
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed.
Sump Gasket
The rod lengths for M5x engines are as follows:
  • M50B25 - 135 mm (non VANOS engine)
  • M50B25TU - 140 mm
  • M52B25 - 135 mm
  • M52B28 - 135 mm
Piston Head
M50 and M52 pistons are
Piston Rings
Crank Pulley
The M50 head is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a higher compression ratio than the M52.
Inlet Cam
The M50 inlet cam lobes are 1mm than the M52.
Exhaust Cam
M50 valve stems are thicker.
VANOS
Main article: VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Exhaust
Off-the-shelf Solutions
DanThe Full manifold and front pipes Contact here
1200 inc. VAT http://www.fritzsbits.co.uk/exhausts.htm
Custom Solutions
cast E36 front manifold
325i E30 system
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its face, or the M42 flywheel.
Despite the work involved, most experienced swappers recommend the use of the M20 flywheel. The existing dual-mass wheel is not only extremely heavy but also problematic, and ties you to a gearbox with worse-performing ratios than its M20 counterparts.
Propshaft
Combinations
E30 320 gear shift rods Ff using the M42 box a new M20 spigot bearing is needed (12mm hole)
M52B28 M20 325i M20 325i E36 328i E36 328i Propshaft should be fitted with a reversed E30 centre bearing
Throttle Cable
Not Turning Over
This is a common problem for those engines fitted with the M20 flywheel. The lip of the flywheel will either be catching on the block where the long rear sump bolts come home, or the bolts that hold the flywheel onto the crank will be too long.
The solution to this is either to grind away a small section of the sump (not recommended), or have the flywheel lightened by removing part of the lip. Either way, the engine and gearbox will have to come out of the engine to cure the problem.
Not Starting
Overheating
VANOS Chatter
Useful websites
See also
