M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
The sump is one of the most important aspects when fitting an M5x engine to your E30, since its size will have an impact on which engine mounts you use and how the engine is positioned on top of the crossmember. The E34 sump will have the main body at the front of the engine, while the E36 sump is at the back.
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed.
Sump Gasket
The rod lengths for M5x engines are as follows:
- M50B25 - 135 mm (non VANOS engine)
- M50B25TU - 140 mm
- M52B25 - 135 mm
- M52B28 - 135 mm
Piston Head
M50 and M52 pistons are
Piston Rings
Crank Pulley
The M50 head is effectively a twin-cam version of that fitted to the M20, and features a similar 'interference' design with valves that protrude into the cylinder, resulting in a higher compression ratio than the M52.
Inlet Cam
The M50 inlet cam lobes are 1mm than the M52.
Exhaust Cam
M50 valve stems are thicker.
VANOS
Main article: VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Exhaust
| DanThe | Full manifold and front pipes | Contact here | |
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its face, or the M42 flywheel.
Despite the work involved, most experienced swappers recommend the use of the M20 flywheel. The existing dual-mass wheel is not only extremely heavy but also problematic, and ties you to a gearbox with worse-performing ratios than its M20 counterparts.
Propshaft
Combinations
E30 320 gear shift rods Ff using the M42 box a new M20 spigot bearing is needed (12mm hole) |
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with a reversed E30 centre bearing
Throttle Cable
Not Starting
Overheating
VANOS Chatter
