M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
The sump is one of the most important aspects when fitting an M5x engine to your E30, since its size will have an impact on which engine mounts you use and how the engine is positioned on top of the crossmember. The E34 sump will have the main body at the front of the engine, while the E36 sump is at the back.
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed.
Sump Gasket
The block is one of the most contentious elements when it comes to M5x engines. The internal structure of M50 and M52 blocks are identical, and aside from a few blanking ports between E34 and E36 engines (to cope with various ancilliaries), all internals are interchangeable.
Unfortunately, aluminium's malleability make it unsuitable for cylinders, and therefore cylinder liners were fitted from a second metal to protect against bore wear. The disastrous choice of material would become a byword for modern BMW engines, and is something that still haunts the company's reputation today. That material was Nikasil.
The Bavarian boffins had looked at the effect of sulphur on Nikasil, and were aware of the damaging affects. For that purpose, they fitted all US engines with iron cylinder liners, but pumped out the Nikasil version to the rest of the world. By mistakenly thinking that the UK was part of Europe, they sent these engines to Blighty, unaware that British fuel is almost as sulphur-rich as American fuel; far more than the Ultra-Low Sulphur petrol available in mainland Europe at the time. Within just a few years, M52 engines were suffering from catastrophic engine wear, causing huge financial and technical headaches for BMW, and a dark cloud was to hang over engines tainted with the Nikasil reputation.
Years later, it's not easy to find a Nikasil block; most were converted to Alusil or scrapped. But the cylinder liners are still an issue. With differing expansion rates, the two metals inside M52 blocks are known to distort the head gasket to the point of failure, while protruding cylinder liners have even been known to buckle heads and strip head bolt threads. In this way, overheating an M52 is highly likely to ruin the engine beyond repair, which is why the M50 iron block is preferred despite its extra weight.
The rod lengths for M5x engines are as follows:
- M50B25 - 135 mm (non VANOS engine)
- M50B25TU - 140 mm
- M52B25 - 135 mm
- M52B28 - 135 mm
Piston Head
M50 and M52 pistons are
Piston Rings
Crank Pulley
The fundamental difference across all M5x engines is the design of the head.
The M50 head is effectively a twin-cam version of that fitted to the M20, and features a similar 'interference' design with valves that protrude into the cylinder. This results in a higher compression ratio than the M52.
Inlet Cam
The M50 inlet cam lobes are 1mm than the M52.
Exhaust Cam
M50 valve stems are thicker.
VANOS
Main article: VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Exhaust
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its face, or the M42 flywheel.
Despite the work involved, most experienced swappers recommend the use of the M20 flywheel. The existing dual-mass wheel is not only extremely heavy but also problematic, and ties you to a gearbox with worse-performing ratios than its M20 counterparts.
Propshaft
Combinations
E30 320 gear shift rods Ff using the M42 box a new M20 spigot bearing is needed (12mm hole) |
| M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with a reversed E30 centre bearing
| M52B28 | M40 | E30 318/320 | The props mentioned have a longer front section
Throttle Cable
Not Starting
Overheating
VANOS Chatter
