M5x
M50
M50 engines weigh 138kg
M50TU
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52 engines weigh 118kg
M52TU
Another Technical Update came in 1998, affecting all the M52 engines with a system called Double-VANOS, which applied the existing VANOS technology to the exhaust camshaft as well. Alongside that, the Block of the engine was changed from cast iron to aluminium, and the engine management system was upgraded.
The sump is one of the most important aspects when fitting an M5x engine to your E30, since its size will have an impact on which engine mounts you use and how the engine is positioned on top of the crossmember. The E34 sump will have the main body at the front of the engine, while the E36 sump is at the back.
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed.
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Cam
VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use.
Engine Mounts
Engines taken from the E34 have their engine mounts bolted to the front of the engine block. To fit these blocks in an E30 you need to bolt E36 mounts to previously unused holes near the middle of the block.
It is preferred to use the engine mounts from the E28 M5.
Around the Engine
Exhaust
Propshaft
Throttle Cable
Not Starting
Overheating
