Technical
Revision as of 16:38, 16 February 2013 by Grrrmachine (talk | contribs)
Technical
Engines E30WireFrame.png Models
Drivetrain Bodywork
Fuel Interior
Intake Electrical
Ignition Instruments
Cooling Exhaust Wheels Suspension Brakes Steering Lights
Engines
Main article: Engines
We're also constantly updating our knowledge on the newer non-E30 engines, to help them fit into your engine bay. Check out our list of engine swaps for more information. If you're thinking of fitting a lump from another BMW, then by far the most popular upgrade is the M50/M52 engine. But don't turn your nose up on the big old M30 engines; if they were good enough for Alpina, then they're good enough for you. There's also the S60/S62 engines for those with cash to spare.
Main article: Drivetrain
Main article: Brakes
Main article: Suspension
Steering
Main article: Steering
Body Styles and Fittings
Main article: Bodywork
Electrical
Main article: Electrical
