M5x
M50
M50 engines weigh 138kg
Engine | Displacement | Power | Torque | Redline | Bore | Stroke | Year |
M50B20 | 2.0 L (1990 cc/121 in³) | 110 kW (150 hp) @ 6000 | 190 N·m (140 ft·lbf) @ 4700 | 6750 | 80mm | 66mm | 1991 |
M50B25 | 2.5 L (2494 cc/152 in³) | 141 kW (192 hp) @ 6000 | 245 N·m (181 ft·lbf) @ 4700 | 6500 | 84mm | 75mm | 1991 |
M50TU
M50TUB20 | 2.0 L (1990 cc/121 in³) | 110 kW (150 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 4700 | 6750 | 80mm | 66mm | 1993 |
M50TUB25 | 2.5 L (2494 cc/152 in³) | 141 kW (192 hp) @ 5900 | 250 N·m (184 ft·lbf) @ 4200 | 6500 | 84mm | 75mm | 1993 |
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52 engines weigh 118kg
M52B20 | 2.0 L (1990 cc/121 in³) | 110 kW (148 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 4700 | 6500 | 80mm | 66mm | 1994 |
M52B25 | 2.5 L (2494 cc/152 in³) | 123 kW (170 hp) @ 5500 | 245 N·m (181 ft·lbf) @ 3950 | 6500 | 84mm | 75mm | 1995 |
M52B28 | 2.8 L (2793 cc/170 in³) | 142 kW (193 hp) @ 5300 | 280 N·m (207 ft·lbf) @ 3950 | 6500 | 84mm | 84mm | 1995 |
M52TU
Another Technical Update came in 1998, affecting all the M52 engines with a system called Double-VANOS, which applied the existing VANOS technology to the exhaust camshaft as well. Alongside that, the Block of the engine was changed from cast iron to aluminium, and the engine management system was upgraded.
M52TUB20 | 2.0 L (1990 cc/121 in³) | 110 kW (148 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 3500 | 6500 | 80mm | 66mm | 1998 |
M52TUB25 | 2.5 L (2494 cc/152 in³) | 123 kW (170 hp) @ 5500 | 245 N·m (181 ft·lbf) @ 3500 | 6500 | 84mm | 75mm | 1998 |
M52TUB28 | 2.8 L (2793 cc/170 in³) | 142 kW (193 hp) @ 5500 | 280 N·m (207 ft·lbf) @ 3500 | 6500 | 84mm | 84mm | 1998 |
The sump is one of the most important aspects when fitting an M5x engine to your E30, since its size will have an impact on which engine mounts you use and how the engine is positioned on top of the crossmember. The E34 sump will have the main body at the front of the engine, while the E36 sump is at the back.
The M50 and M52 pumps are both fitted at the front of the engine, and are both driven from a chain drive from the crankshaft (visible when the sump is removed.
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Cam
VANOS
Main article: VANOS
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Exhaust
Supplier | Offer | Price (£) | Contact |
Fritz' Bits | Full 6 branch manifold and exhaust system
A variety of flywheels can be used, but this entirely depends on which gearbox you are planning to use. The main choice available is the Dual-mass flywheel that comes fitted with the M5x engines, the M20 flywheel which will need some material removing from its face, or the M42 flywheel.
Despite the work involved, most experienced swappers recommend the use of the M20 flywheel. The existing dual-mass wheel is not only extremely heavy but also problematic, and ties you to a gearbox with worse-performing ratios than its M20 counterparts.
Propshaft
Combinations
Engine | Flywheel | Clutch | Gearbox | Propshaft | Modifications |
M52B28 | M20 325i | M20 325i | M20 325i | M20 325i | Modified E30 325 gearbox crossmember using E30/E36 gearbox mounting rubbers
M52B28 | M20 325i | M20 325i | E30 318iS | M20 325i | E30 318iS gearbox crossmember using E30/E36 gearbox mounting rubbers
E30 320 gear shift rods Ff using the M42 box a new M20 spigot bearing is needed (12mm hole) |
M52B28 | M20 325i | M20 325i | E36 328i | E36 328i | Propshaft should be fitted with a reversed E30 centre bearing
M52B28 | M40 | E30 318/320 | The props mentioned have a longer front section
Throttle Cable
Not Starting
Overheating
VANOS Chatter
