Intake
Revision as of 17:28, 3 December 2014 by Grrrmachine (talk | contribs)
Air Filter
AFM
Rubber Boot
If you find that your ICV no longer fits your Rubber Boot, unfortunately this is due to the two types of ICV available. The solution is either to change the Rubber Boot, or change the ICV.
Throttle Body
Throttle Position Switch
Removing and cleaning a TPS is easy, and should be cleaned with Contact Cleaner. It can also be good to drill a 1- or 2mm hole right into the middle of the TPS as well, which will allow oil from the Throttle Body to drain out without blocking the TPS in future.
ICV
Intake Manifold
Lambda
Turbo
Air Leaks
Idling
People overcome this in the short term by winding down the throttle stop screw and so moving the wiper along the carbon track. The ECU now doesn't know the throttle is shut so the factory idle settings are over ridden. So if you've bought a new 318iS with a wonky idle, check the throttle stop screw.
Stalling
K&N Filter
However, a K&N panel filter may yield marginal improvements over the standard filter, as well as other brands such as Piper Cross.
Throttle Bodies
MAF
