Revision as of 14:54, 25 April 2014 by Grrrmachine (talk | contribs)
Rear suspension layout, including braking parts
Front
Front suspension layout
Struts
Shocks
Top Mount
Bump Stop
Springs
The springs are fat coils of steel that compress under force, allowing the entire front suspension to react to the road conditions. There are a wide variety of springs available for the E30, and they are the single biggest factor when contemplating changes to your suspension setup. In terms of compatibility, the spring must be matched to the size of the strut. Note that there are also significant differences in the rear springs if buying a complete set for your vehicle.
Spring Pads
Upper Spring Plate
Stub Axle
Wheel Hub
Wheel Bearing
To remove a wheel bearing:
  3. Remove the 36mm nut
Subframe
Wishbones
Ball Joint removal tool
Since the ball joints in steel wishbones can be pressed out and replaced, it leads to significantly cheaper repairs. If you're hanging on to your E30, it may be worth investing in a ball joint removal tool (pictured) so that you can press them out yourself, rather than having to lug two heavy wishbones to a mechanic.
Lollipops
Ball Joints
Anti-Roll Bar
Main article: Anti-Roll Bar
The ARB itself mounts to the car body using two rubber bushes, held in place with steel shells. The two ends of the ARB then mount to the wishbones via drop links. These drop links operate similarly to ball joints, allowing for lateral movement in the suspension without compromising stiffness, but are actually another type of bush and need to be replaced with the same regularity. There is an upgraded drop link available, which involves using Ford Mondeo parts.
Rear
Rear Beam
Trailing Arms
Rear Wheel Hubs
Rear Wheel Bearings
Rear Shocks
Rear Top Mounts
Rear Springs
Rear Spring Pads
Rear Anti-Roll Bar
Inner Tyre Wear
Maintenance
Bush Renovation
Bigger Struts
Better Shocks and Springs
Coilovers
Lowering
As a simple guideline, 30mm is considered the lowest practical level, while 60mm is the absolute maximum level. That's not to stop others lowering their cars by 80mm or more, but for the design of the E30 it is not recommended. Even at 60mm you will be chewing through a set rear tyres every few months.
Strut Brace
ARB Drop Links
Mondeo ARB fitted
A surprising discovery was made regarding the front drop links that hold your Anti-Roll Bar; you can replace them with the rear drop links from a 2000-2007 Ford Mondeo Estate. These units are rose-jointed, giving a firmer, stronger hold over your anti-roll bar, so they should last a while. They're also available from Lemforder who, being an OEM manufacturer for BMW, guarantee that you're not polluting your E30 with Ford scrap. Lemforder part number is LMI 2581102
This upgrade is pretty much mandatory as part of a front suspension rebuild.
