Rear wheel bearing replacement
Pop off the center cap of the wheel to expose the nut for the driveshaft end.
Remove the brakes. Use a 7mm hex bit to remove the calliper guide bolts and remove the calliper. Remove the carrier bolts with a 19mm socket. Remove the disc screw with a 5mm hex bit.
Your hub is free of the inner bearing and ready for some cleaning. If you don't have a suitable puller, you can always cut it off with a grinder or drimmel which i have done in the past.
The fitting of the drive-shaft and the brakes is the same as the removal this is a good time to check rear brakes.
