Oil
Understanding how the engine is lubricated and what oil to use is the key to a long-lasting and healthy engine.
NOTE: When replacing oils, always fill with the car on an even level surface. Use the dipstick to avoid overfilling the engine, and always fill differentials and gearboxes to the brim.
Which Oil
Winter
Oil Capacity
- M40 for the 316 and 318i - 4.00 litres
- M20 for the 320i and 325i - 4.25 litres
- M42 for the 318iS - 4.5 litres
- M21 for the 324d and 324td - 5.5 litres
Other Fluids
For normal, open differentials, use a 75W-90 oil, such as Silkolene Syn 5, Redline 75W-90 NS, Castrol SAF-XO or Fuchs Sintopoid. You will need approximately 0.9L for a small case differential, or 1.7 litres for the larger (medium case) diff.
For Limited-Slip differentials, use a 75W-140 specifically designed for plate-type LSDs. A normal gear oil will destroy the plates and make it work like an open diff. The recommended options are Castrol racing b373 or Syntrax limited slip (which replaces the old SAF-XJ oil)
You need an MTF for the gearbox and I would go with the Redline MTL, Amsoil MTF or Fuchs Sintofluid. The Millers EP 75w-80 is a good cheaper alternative. You will need 1.15L for the most popular gearbox, the Getrag 240, or 1.25L for the bigger Getrag 260 found on the 325i.
The drain plug is underneath the gearbox and the filler plug is part way up the side, and both are accessed from underneath the car. Always undo the filler plug before the drain, or, if things go wrong, you may be left with an empty gearbox and no way of filling it. You can't pour oil directly into the filler, because of the restricted space around it, so something like a squeezy bottle with a plastic tube attached is required. The correct oil is commonly sold in one litre bottles like this.
Additives
Frequently Asked Questions
