Exhaust
Revision as of 19:11, 17 April 2013 by Grrrmachine (talk | contribs)
Exhaust Manifold
Manifold Studs
Heatshield
Exhaust Pipes
M20 3-piece Exhaust system
320i and 325i systems are interchangeable as long as they are of similar ages. In the BMW inventory, the centre sections of these two models are the same, and the pipe bore is identical; 45mm. However, on the 325i the rear exit pipes are 60mm compared to 45mm for the 320i; this has no impact on the performance of the system, since all other pipes are 45mm.
Downpipe
Centre Box
Catalyzer
Back Box
Lambda Sensor
Bosch Lambda Sensors
Part Number Fitted To Cable Length
258005313 E34/E32 152cm
258005322 M50 525i 145cm
258005324 E30 325i 57cm
258005325 E30 318i 94cm
Mounting
Ticking Noise
Broken Studs
Stainless Systems
Manifolds
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
Note that for some cars there may be clearance issues if you are already using a modified steering rack such as the E36, E46 or Z3 racks. In that case you may want to fit a different alternative steering linkages to ensure you have enough clearance.
Supplier Comment Rating Picture
Alpina Commissioned by Sytners and built by Janspeed, the Alpina manifold is a RHD-specific six-branch. Yields modest gains (5hp) but can go further with surrounding mods. Recommended Alpina.jpg
BTB Over the years have developed a range of impressive manifolds, all of which yield proven power increases of up to 15bhp. Current model is BTB3
BTB3 specifically designed to work with Z3/E36 steering rack upgrade Dyno chart
Highly recommended
Fritz's Bitz Despite the impressive sales pitch, dyno results yield no improvement over standard Not recommended
Griffin Occasionally requires minor modification to fit properly Recommended
Hartge The Hartge H26 used little more than a cam, a chip and one of these manifolds to get +20bhp from the M20. Recommended Hartgemani3.jpg
Hottuning Small power increase and an increase of midrange torque
Incompatible with the E36/E46 steering rack upgrade
Dyno chart Red line shows pre hottuning, purple with hottuning
Budget recommendation
Magnex Proven modest increase (similar to Alpina) from dyno reports Recommended DSC00775.jpg
Quicksilver Claimed to be a perfect copy of the Alpina unit
Racing Dynamics High quality manifold with guaranteed performance increase, but exceptionally rare. Possibly superseded by the BTB v3 manifold. Recommended P1010040.jpg
Sebring Good kit, but unfortunately LHD only Not recommended for RHD cars
Supersprint LHD only Not recommended for RHD cars
Hottuning COPY An unbelievably cheap lump of metal advertised on a popular online auction site
Problems fitting the unit due to bad stud placement, plus poor welding quality. Purely cosmetic
BTB2 alongside a rare Racing Dynamics Manifold 4DEB58E0-403C-4F83-88BF-5AC969561DFD-8416-0000052B4BB4094C.jpg 5EA3166E-84E0-4B11-B330-E26ADC880189-8416-0000052B52BBCDC4.jpg BA4CAA0B-5543-4B25-9A6D-9EC05273E11B-8416-0000052B5BBA5672.jpg
