M5x
M50
M50 engines weigh 138kg
M50TU
M52
M52 engines weigh 118kg
M52TU
Sump Gasket
Crank Pulley
The non-VANOS head, as fitted to the first M50 engines, is a twin-cam unit based around an 'interference' design with valves that protrude into the cylinder, resulting in a relatively high compression ratio. These heads use double valve springs as standard, and a high valve duration of 240 degrees.
Rocker covers were available in plastic or aluminium.
Physically, the covers on these engines are interchangeable, but the cover on top is specific to M50 and M52 engines for a number of reasons.
Primary of these is the engine diagnostics plug. The M50 engine used the first generation diagnostic system known as OBD I, while the M52 used the industry-standard OBD II. The spark plug coils used in the engine are specific to these systems, so something as simple as a cover necessitates a whole changeover of ignition components, which just isn't worth it.
Secondly, plumbing for the crankcase breather hose is different between the engines, so re-working some pipes would be needed.
Finally, Double-VANOS covers are specific to those engines.
Inlet Cam
Exhaust Cam
Lifters
VANOS
Main article: VANOS
VANOS is a variable-valve timing system that determines how long each valve stays open for. Before VANOS, each camshaft was locked into a fixed rotation based on the crank; as the crank turned, so would the cam shafts.
VANOS changed all this by introducing a gearing system which could slow down or speed up exactly when the valves opened, depending on crankshaft position. By installing this gearing mechanism at the front of the camshaft, the opening of the valves could be better co-ordinated to the engine speed, so that a faster-spinning engine can suck in air earlier on each stroke. The time between the intake closing and the exhaust opening is known as Cam-Phasing.
On early VANOS engines, this phasing was a basic switch, giving an ON-OFF characteristic. The engine was either on its idle timing, or its power timing, and the gear system would turn on or off depending on the ECU.
With Double-VANOS, this gearing system was applied to the exhaust cam too, allowing all sorts of clever overlaps regarding when the intake closed and the exhaust opened. The more the overlap, the more efficient the engine.
The actual gearing is a mixture of electric solenoids and hydraulic pressure, and the oil seals in these hydraulic systems are a known issue. If you ask BMW to repair it, they will replace the entire system, but oil seals are available separately and can be fitted with the right tools.
Inlet
Main article: M5x Inlet
The main difference between the 325 and 328 inlet is the plastic manifold and the size of the ports in it. This manifold is 10mm greater (width) in port size over the standard 328. The 325 has 55x25mm port's and the 328 has 45x25mm port size. This equates to a much bigger flow rate; the 325 inlet will flow 50% more than the 328.
Main article: M5x Looms
EWS
Main article: EWS
Temp Sensor
Not Turning Over
Not Starting
Overheating
VANOS Chatter
