Revision as of 15:54, 25 February 2013 by Grrrmachine (talk | contribs)
Front
Front suspension layout
Struts
Shocks
Top Mount
Bump Stop
Springs
The springs are fat coils of steel that compress under force, allowing the entire front suspension to react to the road conditions. There are a wide variety of springs available for the E30, and they are the single biggest factor when contemplating changes to your suspension setup. In terms of compatibility, the spring must be matched to the size of the strut.
Spring Pads
Upper Spring Plate
Stub Axle
Wheel Hub
Wheel Bearing
To remove a wheel bearing:
  3. Remove the 36mm nut
Subframe
Wishbones
Lollipops
Ball Joints
Anti-Roll Bar
Main article: Anti-Roll Bar
Rear
Rear suspension layout
Rear Beam
Trailing Arms
Rear Wheel Hubs
Rear Wheel Bearings
Rear Shocks
Rear Top Mounts
Rear Springs
Rear Spring Pads
Rear Anti-Roll Bar
Inner Tyre Wear
Maintenance
Bush Renovation
Bigger Struts
Better Shocks and Springs
Coilovers
Lowering
As a simple guideline, 30mm is considered reasonable, while 60mm is the safest maximum level. That's not to stop others lowering their cars by 80mm or more, but for the design of the E30 it is not recommended.
Strut Brace
