Technical
Engines
Main article: Engines
We're also constantly updating our knowledge on the newer non-E30 engines, to help them fit into your engine bay. Check out our list of engine swaps for more information. If you're thinking of fitting a lump from another BMW, then by far the most popular upgrade is the M50/M52 engine. But don't turn your nose up on the big old M30 engines; if they were good enough for Alpina, then they're good enough for you. There's also the S60/S62 engines for those with cash to spare.
Main article: Drivetrain
Main article: Brakes
Main article: Suspension
Steering
Main article: Steering
If you find the current setup a little slow and its taking too many turns from lock to lock, you can fit quicker racks from either the Z3 or the E36 M3.
Body Styles and Fittings
Main article: Bodywork
The E30 came in
Electrical
Main article: Electrical
