Oil
Which Oil
Winter
Oil Capacity
- M40 for the 316 and 318i - 4.00 litres
- M20 for the 320i and 325i - 4.25 litres
- M42 for the 318iS - 4.5 litres
- M21 for the 324d and 324td - 5.5 litres
Other Fluids
For normal, open differentials, use a 75W-90 oil, such as Silkolene Syn 5, Redline 75W-90 NS, Castrol SAF-XO or Fuchs Sintopoid.
Drain plug is underneath the gearbox and the filler plug is part way up the side, and both are accessed from underneath the car. Always undo the filler plug before the drain, or, if things go wrong, you may be left with an empty gearbox and no way of filling it. You can't pour oil directly into the filler, because of the restricted space around it, so something like a squeezy bottle with a plastic tube attached is required. The correct oil is commonly sold in one litre bottles like this.
Additives
Frequently Asked Questions
