Oil
- 1 Which Oil
- 2 Oil Capacity
- 3 Other Fluids
- 4 Additives
- 5 Frequently Asked Questions
- 5.1 How is an oil manufactured?
- 5.2 What are the most important substances added to the refined base oils?
- 5.3 What are the differences between mineral, semi-synthetic and fully-synthetic engine oil?
- 5.4 How does oil work?
- 5.5 What's the difference between a 'good' and a 'bad' oil?
- 5.6 What are the likely consequences of using poor-quality oil?
- 5.7 Some oil companies have run advertising campaigns that imply their products have special, unique qualities. Can these adverts be taken seriously?
- 5.8 Please can you explain the grading system? What is meant by the weight of an oil? What does 10W/40 mean for example?
- 5.9 What is the best type of oil to use in a road car for general use? Is fully synthetic a waste of money?
- 5.10 How does oil change in cold weather?
- 5.11 What are the main differences between 2 and 4-stroke oil? Why does 2-stroke oil have to be mixed with fuel?
- 5.12 How important is it to change oil regularly? What are the implications of failing to do so?
- 5.13 Do some types of oil (i.e. fully-synthetic) ‘wear out’ quicker than others? How important are timely oil changes? Can you rely on the frequency suggested by your User Manual?
- 5.14 Does oil have to be warm to do its job properly? Is it important to warm up your engine before using at speed?
- 5.15 What is the difference between road and racing oils?
- 5.16 How does a high-performance oil allow the motor to produce more power?
- 5.17 Why do some engines consume oil? Is this a problem?
- 5.18 If you need to top up your engine oil, how important is it to use exactly the same brand and type?
- 5.19 There are all sorts of additives available which are supposed to improve ordinary oil and reduce friction, improve power output etc. Are they worth a try?
Which Oil
Winter
Oil Capacity
- M40 for the 316 and 318i - 4.00 litres
- M20 for the 320i and 325i - 4.25 litres
- M42 for the 318iS - 4.5 litres
- M21 for the 324d and 324td - 5.5 litres
Other Fluids
For normal, open differentials, use a 75W-90 oil, such as Silkolene Syn 5, Redline 75W-90 NS, Castrol SAF-XO or Fuchs Sintopoid.
Drain plug is underneath the gearbox and the filler plug is part way up the side, and both are accessed from underneath the car. Always undo the filler plug before the drain, or, if things go wrong, you may be left with an empty gearbox and no way of filling it. You can't pour oil directly into the filler, because of the restricted space around it, so something like a squeezy bottle with a plastic tube attached is required. The correct oil is commonly sold in one litre bottles like this.
Additives
In the Dark Ages, engines used blends of refined mineral oils 'straight', with nothing added. The trouble was, even in the slow-revving engines of 80 years ago the oil didn't last very long, and the engines didn't either. Black sludge and corrosion were the killers, and both were tackled in the 1950s with detergent and antioxidant chemicals. (When I was a lad, I used to visit a mate of my Dad's who rebuilt the very popular side-valve Ford engines. The thick crap inside these things was unbelievable! The valve tappets were moving in holes in solid blocks of carbon!) The detergents washed the carbon from fuel combustion off the bores and out of the ring grooves, and at the same time reduced bore and piston ring corrosion. The antioxidants stopped the oil reacting with oxygen in the air, which cut acid sludge formation which in turn reduced corrosion and oilway blockages. Some antioxidants had the useful side-effect of reducing wear as well. This added up to longer oil and engine life, both improving about three times. (Straight oil had to be changed every 1000miles, and even lightly-stressed engines running on it were ready for a full overhaul at 15-20,000.) OK, I admit there were design and metallurgical improvements, but they needed that vital 'liquid component' to be fully effective. Later came dispersant compounds which held the carbon as tiny particles in the oil which didn't settle out anywhere, and slipped through the oil filter as if it wasn't there.(Solid bits in well-used modern oil are about 1/1000mm across; the pores in an oil filter are at least 15 times bigger.) The other big problem with oil used to be cold starting. It was usual to have SAE 20 Winter or 'W' grades, and SAE 30 or 40 Summer grades, and even the so-called Winter types would defeat the starter in serious cold weather. Unfortunately, oil is very thick when it's cold, and very thin when it's hot. To have an oil thick enough to look after a hard working engine, you had to use a grade which was too thick when it was cold.
Before we get into details, the first thing to realise that there is no chalk and cheese difference between mineral and synthetic based oils. After all, the chemical compounds which make mineral engine oils so much better are themselves synthetic. Synthetic lubricant bases are stepwise improvements on mineral oil, with more desirable properties and fewer undesirable ones. The second important point is that there's no one thing called 'synthetic'! There are several different types of synthetic lubricant, and to say something like: 'the Supergrunt GTI TURBO must have a full synthetic' is meaningless unless the 'expert' explains what sort of synthetic he means. Equally, to imply that dreadful things will happen if the 1970 RV8 is run on anything other than good’ ole mineral oil is ridiculous. It may not need a 2007 synthetic, but it isn't going to come to any harm if the owner uses a 2007 synthetic! The most basic type of synthetic is really a special mineral oil. Known as 'hydrocracked' bases, these are made in oil refineries by putting certain types of mineral fraction through special processing, so they cost more than the usual mineral types but not much more. They are useful because they resist evaporation at high temperatures. Although used for years for genuine technical reasons, they are now popular with marketing men because the magic sexy word 'synthetic' can legitimately be printed on the label without spending much on the oil inside the can! Yes, all low-cost 'synthetics' contain anything from a few percent to 20 percent (i.e. 'semi-synthetic') of special mineral oil. Using fairly simple chemical compounds or gases from oil refineries or other sources, it is possible to 'synthesise' or build up tailor-made lubricant molecules which have very desirable characteristics, such as great resistance to cold, heat, evaporation losses or excessive thinning as they get hot. These are the true synthetics, and the two that are used in engine oils are PAOs (poly alpha olefins) and esters. Neither is cheap! PAOs are related to mineral oils, and are the ideal carriers for all the chemical compounds used in mineral oils. Because they do not gel at very low temperatures, all genuine 0W-something oils have to be based on PAOs to pass the 0W test at a sub-arctic -35C. Esters were originally made for jet engine lubricants, and to this day all jet oils are ester-based. Although similar in performance to PAOs, they have a valuable extra trick: they are good lubricants and help to protect metal surfaces. Esters help with transmission and valve train lubrication. 100% fully synthetic oils are actually quite rare, probably because they are very expensive to make, and even more expensive to buy. Even so, an ester/PAO with a very shear stable multigrade polymer is the ultimate oil for high output engines that are worked hard, which means racing.
How does oil work?
If strapped, I’d go for a shear-stable mineral based oil rather than a ‘synthetic’ of dubious stability that’s probably based on modified mineral oil anyway. Unless you’re covering a huge annual mileage, genuine 100% synthetics are probably an extravagance. High mileage long-distance fans can use a light full synthetic and save on fuel and oil changes, and cut overhaul costs if things get to that stage, but more later….
It is a fact that around 90% of all engine wear occurs on cold start because the oil is at its thickest. The colder it gets the thicker the oil becomes and this affects the rate of flow which affects the rate of wear.
These numbers help to explain the oils thickness and therefore cold flow performance at various temperatures.
| Grade | At 0C | At 10C | At 100C |
| 0W/20 | 328.6cSt | 180.8cSt | 9cSt |
| 5W/40 | 811.4cSt | 421.4cSt | 14cSt |
| 10W/50 | 1039cSt | 538.9cSt | 18cSt |
| 15W/50 | 1376cSt | 674.7cSt | 18cSt |
| 20W/50 | 2305cSt | 1015cSt | 18cSt |
Centistokes (cSt) is the measure of a fluid's resistance to flow (viscosity). It is calculated in terms of the time required for a standard quantity of fluid at a certain temperature to flow through a standard orifice. The higher the value, the thicker the oil.
Winters in this country fortunately are not too cold but, compare the thickness of the oil at 0degC and 100degC and you will see the big difference..
Just something to consider on the frosty mornings.
So there we have it, would just like to thank once again John Rowland (R&D Chemist) for taking the time to provide these answers to questions that we are frequently asked.
