Exhaust
Exhaust Manifold
Manifold Studs
Heatshield
Exhaust Pipes
320i and 325i systems are interchangeable as long as they are of similar ages. In the BMW inventory, the centre sections of these two models are the same, and the pipe bore is identical; 45mm. However, on the 325i the rear exit pipes are 60mm compared to 45mm for the 320i; this has no impact on the performance of the system, since all other pipes are 45mm.
Downpipe
Centre Box
Catalyzer
Back Box
Lambda Sensor
| Part Number | Fitted To | Cable Length |
| 258005313 | E34/E32 | 152cm |
| 258005322 | M50 525i | 145cm |
| 258005324 | E30 325i | 57cm |
| 258005325 | E30 318i | 94cm |
Mounting
Ticking Noise
Broken Studs
Stainless Systems
Manifolds
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
| Supplier | Comment | Rating | Picture |
| Alpina | Commissioned by Sytners and built by Janspeed, the Alpina manifold is a RHD-specific six-branch. Yields modest gains (5hp) but can go further with surrounding mods. | Recommended | |
| BTB | Over the years have developed a range of impressive manifolds, all of which yield proven power increases of up to 15bhp. Current model is BTB3
 BTB3 specifically designed to work with Z3/E36 steering rack upgrade Dyno chart  |
Highly recommended | |
| Fritz's Bitz | Despite the impressive sales pitch, dyno results yield no improvement over standard | Not recommended | |
| Griffin | Occasionally requires minor modification to fit properly | Recommended | |
| Hartge | The Hartge H26 used little more than a cam, a chip and one of these manifolds to get +20bhp from the M20. | Recommended | |
| Hottuning | Small power increase and an increase of midrange torque
 Incompatible with the E36/E46 steering rack upgrade Dyno chart Red line shows pre hottuning, purple with hottuning  |
Budget recommendation | |
| Magnex | Proven modest increase (similar to Alpina) from dyno reports | Recommended | |
| Quicksilver | Claimed to be a perfect copy of the Alpina unit | ||
| Racing Dynamics | High quality manifold with guaranteed performance increase, but exceptionally rare. Possibly superseded by the BTB v3 manifold. | Recommended | |
| Sebring | Good kit, but unfortunately LHD only | Not recommended for RHD cars | |
| Supersprint | LHD only | Not recommended for RHD cars | |
| Hottuning COPY | An unbelievably cheap lump of metal advertised on a popular online auction site
 Problems fitting the unit due to bad stud placement, plus poor welding quality. Purely cosmetic  |
Not recommended |
