Exhaust
Exhaust Manifold
Manifold Studs
Heatshield
Exhaust Pipes
Downpipe
Centre Box
Catalyzer
Back Box
Lambda Sensor
| Part Number | Fitted To | Cable Length |
| 258005313 | E34/E32 | 152cm |
| 258005322 | M50 525i | 145cm |
| 258005324 | E30 325i | 57cm |
| 258005325 | E30 318i | 94cm |
Mounting
Ticking Noise
Broken Studs
Stainless Systems
Manifolds
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
| Supplier | Comment | Rating | Picture |
| Alpina | Commissioned by Sytners and built by Janspeed, the Alpina manifold is a RHD-specific six-branch. Yields modest gains (5hp) but can go further with surrounding mods. | Recommended | |
| BTB | Over the years have developed a range of impressive manifolds, all of which yield proven power increases of up to 15bhp. Current model is BTB3
BTB3 specifically designed to work with Z3/E36 steering rack upgrade Dyno chart |
Highly recommended | |
| Fritz's Bitz | Despite the impressive sales pitch, dyno results yield no improvement over standard | Not recommended | |
| Griffin | Occasionally requires minor modification to fit properly | Recommended | |
| Hartge | The Hartge H26 used little more than a cam, a chip and one of these manifolds to get +20bhp from the M20. | Recommended | |
| Hottuning | Small power increase and an increase of midrange torque
Incompatible with the E36/E46 steering rack upgrade |
Bargain basement recommendation | |
| Magnex | Proven modest increase (similar to Alpina) from dyno reports | Recommended | |
| Quicksilver | Claimed to be a perfect copy of the Alpina unit | ||
| Racing Dynamics | One of original, guaranteed performance manifolds, but exceptionally rare. The only thing better than a BTB unit | Recommended | |
| Sebring | Good kit, but unfortunately LHD only | Not recommended for RHD cars | |
| Supersprint | LHD only | Not recommended for RHD cars | |
| Hottuning COPY | An unbelievably cheap lump of metal advertised on a popular online auction site
Problems fitting the unit due to bad stud placement, plus poor welding quality. Purely cosmetic |
Not recommended |
