M5x
M50
M50 engines weigh 138kg
M50TU
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52 engines weigh 118kg
M52TU
Another Technical Update came in 1998, affecting all the M52 engines with a system called Double-VANOS, which applied the existing VANOS technology to the exhaust camshaft as well. Alongside that, the Block of the engine was changed from cast iron to aluminium, and the engine management system was upgraded.
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
VANOS
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Intake
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Around the Engine
Exhaust
1200 inc. VAT |
If you wish to use a more modern gearbox, such as that fitted to the M52, then it should be mounted using an M20 gearbox crossmember, and will need an M3 propshaft to mate up to the differential.
Not Starting
Overheating
M20 Flywheel
m20 clutch w/lightened flywheel, m20 gear linkages + current z3 shortshifter/bearing
