M5x
M50
M50TU
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52TU
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
VANOS
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
Around the Engine
Exhaust
While the 24v conversion doesn't deliver much more raw power, its lower weight does make the E30 a lot more sprightly when it comes to accelerating. It is therefore crucial to make sure your brakes are up to scratch.
Not Starting
Overheating
M20 Flywheel
m20 clutch w/lightened flywheel, m20 gear linkages + current z3 shortshifter/bearing
Useful websites
See also
1200 inc. VAT |
