M5x
M50
M50TU
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52TU
S50
| S50B30 | 3.0 L (2990 cc/182 in³) | 210 kW (286 hp) @ 7000 | 320 N·m (235 ft·lbf) @ 3600 | 7280 | 86mm | 85.8mm | 1992 |
| S50B32 | 3.2 L (3201 cc/195 in³) | 236 kW (321 hp) @ 7400 | 350 N·m (257 ft·lbf) @ 3250 | 7600 | 86.4mm | 91mm | 1995 |
S52
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
VANOS
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Main article: M5x Looms
EWS
Main article: EWS
Engine Mounts
