Exhaust
Exhaust Manifold
If you are thinking of fitting a Turbo to your M20, then the M21 manifold can be fitted upside down with minor adjustment to the bolt holes. Bear in mind that this will limit your choice of turbo due to the small size of the manifold.
Manifold Studs
Heatshield
Exhaust Pipes
Downpipe
Centre Box
Catalyzer
Back Box
Lambda Sensor
| Part Number | Fitted To | Cable Length |
| 258005313 | E34/E32 | 152cm |
| 258005322 | M50 525i | 145cm |
| 258005324 | E30 325i | 57cm |
| 258005325 | E30 318i | 94cm |
Mounting
Ticking Noise
Broken Studs
Stainless Systems
Manifolds
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
| Recommended | Not Recommended | |
| M20 | BTB | Fritz's Bitz
Magnex Sebring (LHD only) Supersprint (LHD only) |
| M40 | ||
| M10 |
