Exhaust
Revision as of 17:26, 16 November 2011 by Grrrmachine (talk | contribs)
Exhaust Manifold
If you are thinking of fitting a Turbo to your M20, then the M21 manifold can be fitted upside down with minor adjustment to the bolt holes. Bear in mind that this will limit your choice of turbo due to the small size of the manifold.
Manifold Studs
Heatshield
Exhaust Pipes
M20 3-piece Exhaust system
Downpipe
Centre Box
Catalyzer
Back Box
Lambda Sensor
Bosch Lambda Sensors
Part Number Fitted To Cable Length
258005313 E34/E32 152cm
258005322 M50 525i 145cm
258005324 E30 325i 57cm
258005325 E30 318i 94cm
Mounting
Ticking Noise
Broken Studs
Depends where it snaps, If it snaps just below the nut you can just unscrew the stud. But if it snaps below the surface it has to be drilled out and possibly the hole will need to be re-threaded (heli coil or a bigger bolt) this is even more of a problem if its the rear ports because the engine or just the head will have to be removed from the car.
Stainless Systems
Manifolds
Alpina M20 Exhaust Manifold
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
Recommended Not Recommended
M20 BTB
Alpina
Hartge
Racing Dynamics
Fritz's Bitz
Magnex
Sebring (LHD only)
Supersprint (LHD only)
M40
M10
